Had the timing belt break on my 1994 Legacy Sport, 2.2 turbo, 4eat.
Mechanic quoted me at 4 hours labor, plus 600 for the parts. I thought the 600 seemed a little bit steep.
Just wondering if anyone has any recommendations on a good kit that has all the essentials plus water pump, cam seals etc...
Thanks for your help in advance!
Timing Belt Kit
Re: Timing Belt Kit
Gates stuff works pretty well and is cheap on amazon and rockauto.
Don't have a kit for the turbo so you will have to mix and match a little.
TCK172 is the belt+pullies
T43204 is the tensioner
42336 is the water pump
should probably pick up a thermostat, gasket, and new upper and lower hoses at the dealership while you're at it.
wvufan8353
Re: Timing Belt Kit
Thanks alot for your help jamal. Mechanic mentioned i should replace cam seals while in that far, would you happen to know a part number for them as well?
I assume the only difference between the N/A kit and the turbo kit is the different water pump?
wvufan8353
Re: Timing Belt Kit
Would this kit work? It looks like the only other things I would have to get would be the hydraulic tensioner and the cam seals?
http://www.autozone.com/autozone/parts/ ... 3_658243_0_
Re: Timing Belt Kit
The old style tensioner that is on these cars doesn't fail on its own. Only way I've ever seen a bad one is when its been subjected to weather and they rust stuck.
wvufan8353
Re: Timing Belt Kit
Rockauto says I need the gates kit no TCK254
that the tck172 is for 93's
Re: Timing Belt Kit
Honestly I ebay'd my timing belt kit and it wasn't too expensive. I got pulleys and belt. You shouldn't have to replace the tensioner. When you do the belt, you need to compress the tensioner very slow or you can ruin it. I use a 6" C-Clamp.
there' shouldn't be much of a difference between 91 and 92-4. only thing different is the water pump because the 91 model has an oil cooler line coming off the water pump.
