engine noob.
ugaucin
engine noob.
Post by ugaucin »
Alright guys I'm a noob to engine work. My legacy is my first car. So not very knowledgeable in the engine area lol. So I was wondering what are the best mods to do to my N/A engine, besides turboing it. I'm wondering. I need lots of help in that area. Still a noob. So your help will be greatly appreciated.
Uriel
1994 N/A Sedan-Daily driver
1994 Touring Wagon 4EAT-Project car #1
DD50
Re: engine noob.
Post by DD50 »
Can't really make big power with a NA engine unfortunately. I mean you can do cam work, exhaust, intake. You could lighten the car a bit so the engine doesn't have to work as hard. I was going to keep my car NA but then decided I wanted to turbo it. You can do it for a decent price as long as you do it right and look in the right places to get parts. IF you really want to keep it NA you can use a frakenmotor which uses parts from different engines and basically piecing it together. It'll be a fun car but eventually you'll max the power out and want more
Proud Owner of a 1992 Winestone Mica Subaru Legacy LSi non turbo with 198,000 miles. Soon to be turboed
Re: engine noob.
How much money do you want to spend? As mentioned, there's really not a lot you can do to the non-turbo setup to make big power gains without tearing into the motor.
ugaucin
Re: engine noob.
Post by ugaucin »
So turboing it is the best thing to do? I do want a turbo. But I don't want it to leave me with no money.
Uriel
robertpaige
Re: engine noob.
Post by robertpaige »
It will definitely be a good chunk of change to turbo your car.
DD50
Re: engine noob.
Post by DD50 »
It's only going to cost me like 800. It depends on how far you want to go.
Ihada147
Re: engine noob.
Post by Ihada147 »
I asked the same question to a lot of different people a while ago, i'd say do a tune up with good quality parts, don't know where you're located but you could bolt on some headers and de-cat and all that good exhaust work... also a noob and got a 93 wagon (btw im on your instagram) but I'm doing some homework on compatibility and I'm probably gonna start off with slightly larger injectors and headers plus an intake. pretty much small things i can swap from newer legacies and imprezas without making the ecu act funky.
ugaucin
Re: engine noob.
Post by ugaucin »
Well came across this today. http://denver.craigslist.org/pts/3895070060.html just wondering if is uses the same wiring harness as my N/A or is it a whole different setup? Do I also need a turbo ecu? If I get the turbo engine I'm planning on a 5 speed swap also
Uriel
robertpaige
Re: engine noob.
You need to modify your N/A harness for some of the turbo sensors and yes you will need a turbo ECU. If you can get the motor for cheap buy it, it's worth it.
