Mods:
Td04(fully rebuilt within the year) to replace my vf11 which was burning oil bad from seals
Tmic
Turbo blanket
Perrin catch can teed into valve breathers to intake(where I get most my oil blowby I believe)
Full catless Invidia tbe
Diamond coilpack
Recent maint:
Rear main seal(within month)
Metal oil seperator plate(within month)
Valve cover gaskets(within year)
New ngk plugs(haven't changed wires)
Compression test(98.96.97.95) or something like that and that's super high altitude at slodrive racing in Longmont, co. Greg said these numbers were fine)
Leak down test- all less than 10% and nothing leaking from the cyl/valves
I know my metal backing plate by the up pipe seeps and I know the cam plug on opposite end of engine om driver side seeps. Other than that my car doesnt leak any oil. It does burn/blow it by though.
I only use Mobil 1 5w/30 and change it every 2k miles, always watch the level and make sure its topped off. Obviously it gets low when I get on it over a weekend or go into high boost a lot. If I granny the car it doesn't as bad at all.
Symptoms:
-Ever since i owned the car it's always ran rich. It runs so rich you can smell it and my exhaust tail pipe is constantly black.
-Always spews out nasty black crap upon cold startups for the first crank ish or so. Here's a pic(usually not this bad, more splattery looking)
-When cruising out with friends they will see me blow a bunch of oil/smoke in high rev/wot and after I accelerate after I've been sitting at a red light or parked for a couple mins
Soo I know my engine is wearing slowly, but can I do anything in the meantime to slow the blowby or make it last longer. I run around 8-12 lbs max when I do get on it but usually drive it within the 1-5lbs daily driving. I think my pcv valve could be bad(felt like this for a while) because Joe had seafoeamed through his pcv hose(turning hose upside down so seafoam goes into pcv valve to intake mani) before with great results and lots of white smoke out his exhaust and when I tried to go through mine I wasn't getting ANYTHING out the exhaust. Like the valve wasn't even funneling the seafoam into the intake manifold. So I've used alternate routes for seafoam since then but its been about a year since I tried through the pcv and thought it was acting funky. Never changed though cuz never saw a cel for it and the car always ran fine.
Could this indicate a bad pcv valve and cause a lot more of my blowby I'm experiencing than I should be? I wanna get this problem under control because reading through the threads I've heard the leakdown test helps show if my rings are going(which I'm sure they slowly are) but my test was fine. Also my car runs phenomenal and afr are usually fine in and out of boost minus running really rich.
