This is my 3rd SS, it is my 1st Post facelift (eww! lol). I got the shell dirt cheap, and it is in way better shape than the 91. I also bought a 91 engine that was COVERED in grease. I still have the preface glass headlights that I never ended up installing, so I'll do a front end swap hopefully with help. Here are my plans:
I plan to run this more or less stock (with the huge exception of the tranny setup! (EDIT: back to stock SS tranny - I love the tall gearing, especially in 5th!) Also, will run a td04 and slanty intercooler for the first iteration (edit again: td05 and 06/07 wrx tmic and revtronix or robtune ecu with 550's) until I complete the ej207 swap in my RS. This needs to be a reliable DD, so nothing crazy going on for now.
92 Shell - $400
Bone stock EJ22T - $600 *spun bearing after 60 miles, no thanks to seller 03Bug aka Lucci*
Dirty ass ej22t - $220 * spun bearing after 1000 miles. Junkyard engine ftl!
Dirty ass ej22t from the junkyard again - re-ringed and fresh bearings - $400 total
ej22t felpro upper gasket set - $220
Reseal kit for tranny - $80
1991 SS Tranny and diff - $250
6mt clutch setup - $100 (including resurface flywheel), used "gently"
I have modded this tranny to clear the 6mt flywheel
92 SS engine wiring harness - $50
05 WRX front brakes incl good rotors - $75
04 Outback H6 rears - Free!
Phase I SOHC timing belt kit - $180
Akebono front pads, cheapo rears - $100
Misc PCV bulk hoses - $30
PCV Valve - $4
Coolant Temp Sensor - $45
Knock Sensor - $45
Moog Balljoints & tie rod ends - $150
NGK Copper plugs and wires - $50
STI Struts - $200
Ver 1-2 WRX front seats - $350
Rear 98 RS seats - $50
Group N engine & tranny mounts - $100
td05 - $200
GFB EBCS - $250
USA made Thermal Zero turbo blanket $50
Roughly $(too much) spent so far.
Before
After
All the grime that's left is carbon and stained aluminum. Not coming off easily. I soaked the engine overnight with degreaser, and I'm reasonably happy with the result.
