using a na intake wiring harness for turbo swap
turbo wagon
Post by turbo wagon »
I was going to use the intake manifold harness from my na ej22 motor for the turbo motor so I can keep it plug and play, also I am running a rob tune Ecu . Is there any problems with that?
93 legacy wagon 5speed -Ej22t swap
92 SVX
86 vanagon with an SVX swap
01 outback the lactation-station-wagon
Re: using a na intake wiring harness for turbo swap
You will just need to relocate the coolant temp sensor wiring harness connectors to the driver's side of the harness vs. the passenger side. I did this when I did my turbo engine swap. I just took the wiring loom apart and moved the wires over....there's no need to cut and splice anything.
legsportwag
Post by legsportwag »
Also ground plug is different for 92-94 cars. Turbo is round na is square
