91 Legacy SS AT to Manual swap, B15 connector Help???
dadondadasuby1969
Post by dadondadasuby1969 »
Hey guys Im trying to finish up a AT to Manual swap on a 91 legacy ss sedan, Iv got just about every thing together but when it comes to actually being able to start the car iv got nothing. Iv read on a couple threads that you have to jump pins 11 and 12 on the B15 connector from the AT tans harness. Problem is My uncle junked the AT trans a few weeks after I removed it thinking it was junk. Im wondering if there is any other way of getting the car to start?? I went to the dealer and bought a brand new AT trans harness but im not sure its got the correct connector on it. It has a b-4 stamped on it very small but idk if that's means something or not. Im gonna try and get a picture up of the harness I just purchased, I don't wanna cut it up before knowing its the right one. Im hoping someone on here can shed some light and help me out, Thanks.
wtdash
Re: 91 Legacy SS AT to Manual swap, B15 connector Help???
Post by wtdash »
HI and Welcome!
Did you read Josh/Legacy777's write-up on his swap HERE?
Also, a USED trans harness from any '90-'98 4EAT - turbo or NA will work, from what I've read...if you have a wrecking/salvage/pull and save yard.
GL,
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Welcome to the BBS.
The harness you have is the B16 harness. If you can take that back, I'd take it back.
Take a look at my write-up. There's a lot of good info there.
What you can do is peel the wiring loom back and either de-pin pins 11 & 12 from the chassis side harness and splice them together, or you can cut those wires just behind the connector and splice them with a weather proof butt connector or solder and heat shrink.
If you have any questions, let us know.
