turbo wagon help!
ugaucin
turbo wagon help!
Post by ugaucin »
Im having problems with my turbo wagon. The problems are #1. The back two cylinders are not firing. #2 I got a check engine light for the fuel injectors. The cel just turned on today. My wagon has been out for about a week. I got a new coil pack and the two cylinders still aren't firing. Any ideas?
Uriel
1994 N/A Sedan-Daily driver
1994 Touring Wagon 4EAT-Project car #1
Re: turbo wagon help!
Have you verified whether the back two cylinders are getting spark or if the injectors are not firing?
Which codes were present in the ECU?
Have you done the active diagnostic to see what active codes are coming up? If not, I'd suggest doing that. The instructions are on my site.
ugaucin
Post by ugaucin »
Yeah did it with a spark plug tester, no spark in cylinder 3 and 4. Codes we're 14,15,16,17, and 22. I change out the knock sensor about 3 months ago so I don't know why that popped up. Now this is something I can't really figure out.
Uriel
wtdash
Post by wtdash »
Hi,
I'd check your wiring harness @ the coil pack - follow it down and around the throttle body.
Also, try another igniter....Josh can confirm that.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
ugaucin
Post by ugaucin »
Tried another igniter same problem. Im going trace all my wires tomorrow.
Uriel
ugaucin
Post by ugaucin »
Any ideas guys?
Uriel
92ColoradoTurbo
Post by 92ColoradoTurbo »
Just throwing out ideas but: change ecu, re-ground all your ground points, new spark plugs, new injectors (cause the cel), check voltage on your coil pack plug
Sent from my XT1080 using Tapatalk
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
Have you tested your coil pack? Check the coil pack:
http://www.main.experiencetherave.com/s ... cktest.jpg
If it tests out good, check the wiring from the coil pack to the igniter, and then from the igniter to the ECU. If all that is good, then it's possible that ignition channel on the ECU got fried or isn't working.
