Check engine light
93legacySS
Check engine light
Post by 93legacySS »
I read my codes and all but I was wondering if it's ok to leave the black connectors unplugged or do you have to have them together?
Re: Check engine light
When driving around normally you leave them unplugged.
93legacySS
The black ones like I said correct? Because they were plugged in when I got under there
There are two black ones under the dash. One set with a stripe and smaller connector, those stay plugged in. The all black ones stay unplugged.
wtdash
Post by wtdash »
+1 and the ECU code-reading plugs should be just one wire on each connector. The other one is part of the seat belt lights and/or warning (I was just messing w/this last week!).
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
James614
Post by James614 »
wtdash wrote:The other one is part of the seat belt lights and/or warning (I was just messing w/this last week!).
TD
Is this why my seatbelt light has been flashing ever since my swap? :shock:
wtdash
Post by wtdash »
^ Probably...mine got unplugged and was blinking, too.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
