hangs to low
turbo970
hangs to low
Post by turbo970 »
heres how low my exhaust sits
rallyak
Re: hangs to low
Post by rallyak »
Is the bracket on the transmission connected? And the one on the mid pipe?
Charles
Re: hangs to low
That's not right. It should be much higher than that. Can you take a picture of the down pipe. I second Charles's question, is the bracket holding the downpipe to the transmission connected?
turbo970
Re: hangs to low
Post by turbo970 »
yuppers it is and theres a pic of how low the dp sits on the shorty dp thread. its the best i can get
Re: hangs to low
Then I would say your problem stems from your down pipe sitting too low, which is probably due to how it was made. The down pipe & mid pipe are all relatively level and don't change elevation. Its elevation is determined by the bend point on the down pipe.
turbo970_2
Re: hangs to low
Post by turbo970_2 »
so would a meagan racing dp fit better?
James614
Re: hangs to low
Post by James614 »
I know a lot of guys run the Megan and I haven't read any complaints. I have a cheap@ss HKS flat-flange and it sits at the right height. I'd search for threads about down pipe fitment, and see what others have recommended.
turbo970_2
Re: hangs to low
kk this one was a dna racing set up. i dont want to go crazy expensive but not super cheap
turbo970
Re: hangs to low
Post by turbo970 »
turbo970
Re: hangs to low
Post by turbo970 »
Re: hangs to low
If they are meant to work with the non-twin scroll turbo WRX's it'll work with your Legacy and just the length would need to be adjusted.
I really think your current problem is poor quality and/or sloppy craftsmanship.
turbo970
Re: hangs to low
Post by turbo970 »
they both say for 02-07 wrx
oldscoobyturbo
Re: hangs to low
Post by oldscoobyturbo »
i've seen this before that gap at the tranny cross member is likely one of two things.
1. the hanger on the downpipe is possibly bent up or not in the proper position for good ground clearance.
2. the downpipe is too tall or has the wrong bend for proper ground clearance
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
turbo970
Re: hangs to low
Post by turbo970 »
i have a new dp waiting to go on. its a better quality one. its a invidia dp with 2 O2 bungs the shop thats putting it on said it will hug up alot better
TurnNburn
Re: hangs to low
Post by TurnNburn »
I had the same problem with my turbo back and had to shorten the height of my STI down pipe by about 3 inches to make it fit snuggly.
1990 NA 2.2 Open Light rally car
