subiedoutlegacy's 1991 Pre-facelift Sport Sedan
subiedoutlegacy
Post by subiedoutlegacy »
Before I begin my explanation of my build I would like to first explain what began my love of first gen legacy's. This was the purchase of my first one from Mark aka sqc151 which was a 1994 Legacy Lsi wagon which originally looked like this;
Image20130423_164019 by stephanieapgar, on Flickr
Image20130423_164027 by stephanieapgar, on Flickr
Very Shortly after I decided to slam the crap out of the poor thing and put gold 17 rotas on it but i soon learned my lesson when three of the four coil overs blew out.
Image20130430_142520_HDR by stephanieapgar, on Flickr
Image20130524_151507 by stephanieapgar, on Flickr
Image20130601_145038_HDR by stephanieapgar, on Flickr
Then I proceeded to blow then head gaskets...3 months after buying it.
Image20130825_200027 by stephanieapgar, on Flickr
Image20130827_085018 by stephanieapgar, on Flickr
Cleaned up the headlights;
Image20130622_184252 by stephanieapgar, on Flickr
New stereo;
ImageDSCF4246 by stephanieapgar, on Flickr
Nardi Steering wheel and shifter;
ImageDSCF4244 by stephanieapgar, on Flickr
I'm sure you get the point by now...While doing work on my wagon I soon learned about the little known but very loved Legacy Sport Sedan. Naturally began my search for one. This lead me of course to browsing criegslist looking for anything in an arms reach. This brought me to Greeneville, Tennesse a mere 10 hours away :lol: These are the pictures that I saw when I saw the ad.
Image00G0G_cOTZKVQbdSV_600x450 by stephanieapgar, on Flickr
Image01616_97KmO0CfrpI_600x450 by stephanieapgar, on Flickr
Image00606_yBVPWyHVK4_600x450 by stephanieapgar, on Flickr
Image00Y0Y_fekrGuWlXry_600x450 by stephanieapgar, on Flickr
So in my excitement I rented a uhaul and traveled those ten hours in hopes that what I saw in the ad was true, of course this was quite the leap but hell it was up for 1500 with 144,000 miles on it and they even posted the vin! Off I went to see this future to be my car and of course fell in love, this car literally has no rust whats so ever. The engine was almost clean enough to eat off of! Minus the need of valve cover gaskets. The only down side was the fifth gear was blown on the trans, but hell if that's it then not bad. Well I of course bought it and brought it back home.
Image20140516_162103_HDR by stephanieapgar, on Flickr
Image20140516_191946_HDR by stephanieapgar, on Flickr
Image20140516_192004_HDR by stephanieapgar, on Flickr
Image20140516_191957_HDR by stephanieapgar, on Flickr
91 Mica Ruby Legacy Sport 550 Robtune
94 White Pearl Legacy L SOLD
04 San Remo Red Impreza WRX
04 Java Black Pearl Impreza STI
94 Crimson Pearl Legacy Sport Partout
10wrxing
Re: subiedoutlegacy's 1991 Pre-facelift Sport Sedan
Post by 10wrxing »
Both cars look nice!
Do you still have the wagon?
The wagon looks hot lowered with the golds.
That wagon makes me need to drop mine.
Looks like a good find!
subiedoutlegacy
10wrxing wrote:Both cars look nice!
Yup still got the wagon! I miss it lowered looked so good but it was really hard on the car. It's now running on 2004 sti struts.
subiedoutlegacy
A few weeks after having the car i noticed the engine was moving a lot with rough idle this began my long list of figuring what was wrong, firs was the Crank pulley and oh my was that bad
20140602_150338 by stephanieapgar, on Flickr
20140602_150528 by stephanieapgar, on Flickr
subiedoutlegacy
After replacing the crank pulley I thought all my rough idle troubles would be solved but boy was i wrong...Car idled erratically and vacuum was all over the place so I figured might as well replace all the PCV.
20140619_143648_HDR by stephanieapgar, on Flickr
The hoses I may say were as hard as a rock and it took about two days to replace every single one.
After I was finished I was extremely excited to start the car and finally get to driving running good! (Mind you this was the day before OC AWD and WBM so I was dying to bring it) Unfortunately the PCV fix did nothing to solve my issues and my CEL prevailed.
subiedoutlegacy
https://flic.kr/p/oV4CrL Video of after finishing the PCV
subiedoutlegacy
After that I began to chase the codes that were given to me which were
14 (injector 1)
15 (injector 2)
16 (injector 3)
17 (injector 4)
35 (Purge solenoid valve)
49 (Mass air flow)
So I replaced the MAF
20140802_101742_HDR by stephanieapgar, on Flickr
Also replaced the
Fuel filter
Fuel Pressure Regulator
Fuel Pump (WRX)
One injector just to test if they really are bad
Wires
Spark Plugs
As you can tell i got to the point of throwing money at it...
subiedoutlegacy
After all this there was no change the car still didn't run right, at this point I had owned the car for 3 months and only drove it less than 1,000 miles. I was beyond frustrated and decided to get the car smoke tested as i noticed cylinder 1's spark plug was showing up lean. What I discovered was a complete surprise but a crack on runner one of my intake manifold!
20140823_111649_HDR by stephanieapgar, on Flickr
Which i promptly got welded thanks to my work hooking me up!
20140912_164926_HDR by stephanieapgar, on Flickr
Also here is a better shot of the car!
20140817_132611_HDR by stephanieapgar, on Flickr
subiedoutlegacy
Next priority after the engine troubles was the blown transmission which came from a donor rusted exact same model Legacy sport!
The trans is a 1996 STi RA trans and man this thing has short gears!
Image20140907_135104 by stephanieapgar, on Flickr
Image20140907_135121_HDR by stephanieapgar, on Flickr
Image20140907_141905_HDR by stephanieapgar, on Flickr
Image20140907_184915 by stephanieapgar, on Flickr
rallyak
Post by rallyak »
I have ran in to cracked intake several times in that same place, that weird.
Charles
subiedoutlegacy
rallyak wrote:I have ran in to cracked intake several times in that same place, that weird.
Yeah I couldn't believe it either I was told I possibly "over" torqued it but that's impossible since i used a beam torquing wrench and tightened it on the low end of the range.
sqc151
Post by sqc151 »
glad you finally went and got the smoke test... as you see it will drive you crazy.
nice things are finally coming along.
with the cars and yard pics, it looks like a few of my journals... :P
subiedoutlegacy
RS RA Trans install
Image20140920_105928_HDR by stephanieapgar, on Flickr
Image20140920_135358_HDR by stephanieapgar, on Flickr
Image20140920_171840_HDR by stephanieapgar, on Flickr
subiedoutlegacy
New wheels Prodrive P7's
ImageIMG_1461 by stephanieapgar, on Flickr
ImageIMG_1490 by stephanieapgar, on Flickr
Image10630568_10203777697596201_3821817176889758596_o by stephanieapgar, on Flickr
subiedoutlegacy
Last but not least new steering wheel! JDM V3 GC8 nardi wheel.
Image20141031_232519_LLS by stephanieapgar, on Flickr
What are your impressions of that tranny? Also whats it's tranny code? Keep up the good work, your car has come so far and looks great!
subiedoutlegacy
mike-tracy wrote:What are your impressions of that tranny? Also whats it's tranny code? Keep up the good work, your car has come so far and looks great!
Thanks I'm really happy with the progress so far! The trans code is 6B-TY752VB3EA and I love it, it keeps me in the power band but naturally my gas suffers but once I upgrade the turbo it will definitely boogie.
subiedoutlegacy
Glass headlights just came in for the Sport Sedan! Also rebuilding a 22t motor and swapping it in the wagon!
Image20141110_180237_HDR by stephanieapgar, on Flickr
ImageIMG958153 by stephanieapgar, on Flickr
subiedoutlegacy
Progress so far on the 22t I'm rebuilding at my shop to go in the 94 Legacy LSI it may be dirty on the outside but the inside of this thing is clean!
Image20141122_102737_HDR by stephanieapgar, on Flickr
Also broke the exhaust manifold upon removing it.
Image20141122_102750_HDR by stephanieapgar, on Flickr
Image20141122_120246_HDR by stephanieapgar, on Flickr
Image20141122_124224_HDR by stephanieapgar, on Flickr
Image20141122_131204_HDR by stephanieapgar, on Flickr
subiedoutlegacy
Got to take the legacy sport out in the snow today! Here's some screenshots video will be posted soon!
ImageScreenshot 2 by stephanieapgar, on Flickr
ImageScreenshot 1 by stephanieapgar, on Flickr
subiedoutlegacy
Robtune 550 install!
Image20150702_103939 by Stephanie Apgar, on Flickr
Image20150702_123401 by Stephanie Apgar, on Flickr
left to right, TD05, TD04 & VF11
Image20150702_123458 by Stephanie Apgar, on Flickr
Image20150702_170200 by Stephanie Apgar, on Flickr
Image20150702_145032 by Stephanie Apgar, on Flickr
Image20150721_194901 by Stephanie Apgar, on Flickr
tkammen
Post by tkammen »
No 4 pot pictures :(
2005 WRX
V9 Engine Swap, V7 6spd, VF37
1992 Legacy SS
2022 Ford Maverick
Post by SILINC3R »
sigh, this makes me miss mine. JDM TD04 is where it's at
subiedoutlegacy
SILINC3R wrote:sigh, this makes me miss mine. JDM TD04 is where it's at
With the robtune 550 I have the td05 in it and I love it.
