On a cold start it idles around 2500 or 3000 rpms but boosts perfectly with tons of power. As soon as my heat gauge starts to register it drops to normal idle but if I give it any more than 2 or 3 psi (set to peak at 11 but never makes it there) I start missing.
Now when that happens I lose boost. I don't know if the missing is causing the loss of boost or if the loss of pressure is causing the missfire.
I'm gearing up to put a td04 on in place of my vf11 but I want to know I don't have any major issues before I start tearing it apart. Any help would be appreciated greatly.
