12v at injectors with key off on turbo Legacy models?
macipusy
Post by macipusy »
So I have noticed a strange situation troubleshooting my new swap in the Turbo Legacy.
I noticed that there is 12v at all times at the injectors with no keys in the ignition. I looked through the FSM wiring diagrams, and it seems that this is correct. The yellow 12v wire is routed directly from the battery....no relays anywhere in line.
Anybody else notice this? On the n/a model the injector 12v is routed through the ignition relay.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Re: 12v at injectors with key off on turbo Legacy models?
I noticed that on Kleinkid's car.
TurnNburn
Post by TurnNburn »
Nissans do that too, the ECU grounds them when it wants to inject fuel
1990 NA 2.2 Open Light rally car
The 90-91 models did this too and it looks like the turbo legacies as well. As you noted, it's normal. If it's causing you issues, I'd insert a relay in the fender or in the cabin so that wire is only energized with the ignition.
