any chance the female side simply needs to go to ground? or the ecu.
per the ecu pin out i am using. i do not see a second wire to green plug from ecu?
http://www.shoptalkforums.com/viewtopic.php?t=136053
thanks
jim
PS: my car also have trans bind, but i may just pull engine for a swap into another car. wanted to drive it some first but don't want to put much money into it.
(ECU plug position - wire color - description - destination) (if you have three engine plugs, not two, the pin # is in parenthesis)
A1 - empty
A2 - yellow/red - Ignition on - Don't wire this one yet.
A3 - Empty
A4 - Empty
A5 - Empty
A6 - White - O2 sensor - O2 sensor plug 4
A7 - Black/Yellow - Water temperature - F26 pin 5 (pin 2 if three plugs)
A8 - Red - Air flow meter - Air flow meter plug pin 1
A9 - Black - Air flow meter - Air flow meter plug pin 4
A10 - White - Air flow meter - Air flow meter plug pin 2
A11 - Black red - ground - don't wire this yet
A12 - empty
A13 - yellow/red - Ignition on - Don't wire this one yet
A14 - empty
A15 - Yellow/red - Hot from battery - don't wire this one yet
A16 - Red/Yellow - cut it
A17 - Black - Shield for O2 sensor - connects to shield on grey sensor wire
A18 - empty
A19 - Gray - Air flow meter shield - connects to shield on grey air flow meter wire
A20 - AT/MT selector
A21 - Red/green - Water temperature - Connects to F26 plug pin 6 (pin 3 for three plugs)
A22 - Black/red - ground - don't wire this yet
B1 - white - Throttle position - to F26 pin 2 (pin 7 on three plugs)
B2 - black - Throttle position - to f26 pin 4 (pin 5 on three plugs)
B3 - Red - Throttle position - to F26 pin 3 (pin 4)
B4 - White - Cam position - to cam plug pin 1
B5 - Black - Cam position - to cam plug pin 2
B6 - Grey - Cam shield - to cam plug pin 3
B7 - White - Throttle shield - to throttle position shield
B8 - Blue - Air flow meter - to air flow meter plug pin 5
B9 - Blue/pink - park switch - do not wire this yet
B10 - Light green - Neutral switch - do not wire this yet
B11 - Green/Black - speed sensor - do not wire this yet
B12 - Yellow - ign relay - do not wire this yet
C1 - Black - Crank angle sens - to crank plug pin 1
C2 - White - Crank angle sens - to crank plug pin 2
C3 - Shield - Crank angle sens - through shield to crank plug pin 3
C4 - Shield - knock sens - to shield for knock sensor
C5 - White - knock sens - to knock sensor plug
C6 - Brown - throttle position - to f26 pin 1 (pin 6)
C7 - Light green/red - select monitor - not needed
C8 - Green/white - select monitor - not needed
C9 - Blue/red - A/C compressor - not needed (connect to positive for high idle)
c10 - Red/yellow - connect to starter selenoid (hot when starting only)
c11 - Green/black - california mode switch - goes to f26 pin 7 (pin 12) (grounded for CA mode, determined by engine wiring)
c12 - Red/Black - read memory - to black "read memory" plug
c13 - Orange - test mode - to green "test mode" plug
c14 - empty
c15 - Blue/yellow - select monitor - not needed
c16 - Black/blue - tachometer - to tachometer
d1 - Black - idle air control - to f26 pin 12 (pin 14)
d2 - White - idle air control - to f26 pin 11 (pin 13)
d3 - empty
d4 - empty
d5 - light green - ignition relay - do not wire this yet
d6 - White/blue - CPC senenoid - to f25 pin 2 (pin 7)
d7 - empty
d8 - empty
d9 - Green/white - Ignitor - to ignitor plug pin 2
d10 - Yellow/blue - Ignitor - to ignitor plug pin 1
d11 - Blue/white - injector #3 - to f25 pin 11 (pin 15)
d12 - Light green - injector #2 - to f25 pin 10 (pin 14)
d13 - brown - injector #1 - to f25 pin 9 (pin 13)
d14 - black/white - ground - do not wire this yet
d15 - black - ground - do not wire this yet
d16 - empty
d17 - Red/blue - fan control - do not wire this yet
d18 - white - select monitor - not needed
d19 - red/yellow - check engine light - ground check engine light here
d20 - empty
d21 - empty
d22 - Blue - a/c cutout relay - not needed - turns off a/c compressor if full throttle... hook nitrous selenoid here
d23 - Light green/black - fuel pump relay - do not wire this yet
d24 - Black/yellow - ground - do not wire this yet
d25 - black/yellow - ground - do not wire this yet
d26 - Blue - injector #4 - to f25 pin 12 (pin 16)
