Clueless on lack of power and rough driving...
Hello, so I have a '93 Subaru Legacy SS that I had the 2.2 rebuilt with forged internals along with a new water pump and timing belt. I then had the EJ20G ECU swap done. All done by 2 different shops. I have replaced the plugs, wires, coil pack, ignitor module, had the injectors flow tested and all Ohm read at 11.8. The injectors are grey side feeds, which I believe are 440 or 480's. The problem I am having started off intermittently and is now constant. I am having a misfire in cylinder 2, which I have narrowed down by the looks of the spark plug and no change in idle when I pull injector clip. Cylinder 2 does have spark and when I pulled the plug out it was wet which has me confused. Does anybody have any ideas?
Re: Clueless on lack of power and rough driving...
Hi
How did the shop wire in the EJ20 ECU?
If you still have your stock coil pack AND ignitor and didn't use the RobTune converter that's likely problem #1.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Thanks for your reply.
I do not know how the shop installed the ECU but has done several already, according to what they're saying. I did not use a Rob Tune setup. I used a Enduring Solutions ECU setup. As far as I know I did not need a converter for the coil pack or module cuz the ESL ECU eliminated the need for that if I understand it correctly. The shop has done 5 ESL swaps, including his own car, and has never had this problem before.
Pntaste4evr99
- Winestone Cowboy
Check the ground wire on the back of the intake, and the ECU if it's getting a good ground
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Ok, will do. Thank you.
Sarac,
Any update/feedback whether you are still having this issue or not?
