1993 RHD Legacy Wagon Turbo Build
turbo_gc8
Post by turbo_gc8 »
Here is my 1993 Legacy I picked up a little over a month ago. I had been looking for a RHD wagon for a while because I wanted the manual transmission.
The previous owner had swapped in an EJ22 turbo from an North American legacy (I assume the EJ20G had quit) and in the process was changed to wasted spark. A lot of stuff was just jammed together and a mess. I've been mainly fixing messes while doing upgrades
Since I've had it I have installed, VF48 turbo, FMIC, 550cc injector, ESL Daughterboard, coilovers, BBS RK wheels, HKS catless downpipe, 3" catback exhaust, and AEM wideband.
I just picked up a rotated turbo conversion, Garrett GT3076R turbo, jecs 850cc injectors, Tial 38mm wastegate and Tial 50mm blow off valve that I will be installing over the next few weeks. I plan on sleeving the EJ22T closed deck out to 100mm and machining it for a #5 thrust, and building the bottom end over the winter. I also have a set of EJ20G WRX heads that I will be using at the same time and converting back to coil on plug using 2004 STI coil packs.
Current:
2006 STI GT3582R 29psi on pump/meth
1993 RHD Legacy wagon S366 turbo.. number soon
1993 RHD WRX EJ205 swap
Pntaste4evr99
Winestone Cowboy
Re: 1993 RHD Legacy Wagon Turbo Build
Post by Pntaste4evr99 »
Badass!
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Nice looking wagon!
turbo_gc8
Post by turbo_gc8 »
Anyone know how I make a build journal? It doesn't give me the option and I would like to share my progress on this!
Current:
I sent you a PM about being added to the Build Forum group.
ride_child
Post by ride_child »
i want your roof.
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
turbo_gc8
Post by turbo_gc8 »
ride_child wrote:i want your roof.
Haha with the big bump? It has a wicked dent in it from where a tree fell on it when the PO had it
Current:
