I'm tracing some electrical connections using the schematic in my
Haynes manual. I'm stuck at the MPFI control module because I can't
find it. I have a 90 Legacy wagon. Anybody know where I can find this
module on my car?
Marc
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/Pv4pGD/4m7CAA ... /XoTolB/TM
MPFI control module
acroxford@hypermall.net
MPFI control module
Should be right above the steering column under the dash.
this
> module on my car?
> Marc
Monitoring Service trial
http://us.click.yahoo.com/Gi0tnD/bQ8CAA ... /XoTolB/TM
this
> module on my car?
> Marc
Mark Ward
MPFI control module
Turbo?
There is no separate MPFI unit, it is part of the computer. The is a couple
of sensors that effect it that are separate. There is 4 wires that go to
the computer that control the injectors plus a common ground. What problems
are you having? I have been very intimate with the wiring harness of our car...
Mark
www.rrunracing.com
>module on my car?
>Marc
Mark
www.rrunracing.com
>module on my car?
>Marc
Wilson, Tim
MPFI control module
what si a mpfi control module?
-----Original Message-----
From: acroxford@hypermall.net [mailto:acroxford@hypermall.net]
Sent: Wednesday, October 17, 2001 2:38 PM
Subject: [BC-BFLegacyWorks] Re: MPFI control module
this
> module on my car?
> Marc
this
> module on my car?
> Marc
Kylie M. Clark
MPFI control module
I'm guessing Multi Port Fuel Injector control module
Sent: Wednesday, 17 October 2001 3:18 p.m.
To: 'BC-BFLegacyWorks@yahoogroups.com'
Subject: RE: [BC-BFLegacyWorks] Re: MPFI control module
this
> module on my car?
> Marc
zZz
zZz
FREE COLLEGE MONEY
this
> module on my car?
> Marc
zZz
zZz
FREE COLLEGE MONEY
mhmarcherman@yahoo.com
MPFI control module
The car is non-turbo. My A/C compressor won't kick on. I've been
tracing wires and I stopped at the 4 conductor compressor cut relay.
I have power at the propper constant + connector and I can make the
compressor kick on by jumping the + to the apropriate connector which
leads directly to the compressor. So I have two more connectors left
to check. One wire (blue) goes to the MPFI control unit according to
the schematic I have. So I need to troubleshoot at this connection. I
know that the A/C system has the propper pressure - the problem is
definately electrical. So now I have two different opinions. You tell
me that there is no separate MPFI module and another poster says it's
above the steering column. I'll check tomorrow to see if I can find
it above the column and I'll be waiting for your suggestion too.
Thanks,
Marc
--- In BC-BFLegacyWorks@y..., Mark Ward <mark@r...> wrote:
> Turbo?
a couple
go to
problems
of our car...
> Mark
> www.rrunracing.com
this
> >module on my car?
> >Marc
FREE COLLEGE MONEY
Thanks,
Marc
> Turbo?
a couple
go to
problems
of our car...
> Mark
> www.rrunracing.com
this
> >module on my car?
> >Marc
FREE COLLEGE MONEY
Mark Ward
MPFI control module
Found it... sorry about that.
MPFI unit has 6 wires correct? Blk/bl, Red/yel, Grn/Black go to the
instrument cluster and Red/blue and Blue go to A/C system and Red/yel are
for the A/T control unit....
Found it on the diagram.
You have checked the wires from the engine bay back?
Mark
>Thanks,
>Marc
> > Turbo?
>a couple
>go to
>problems
>of our car...
> > Mark
> > www.rrunracing.com
>this
> > >module on my car?
> > >Marc
Mark
>Thanks,
>Marc
> > Turbo?
>a couple
>go to
>problems
>of our car...
> > Mark
> > www.rrunracing.com
>this
> > >module on my car?
> > >Marc
