1. Where can I find Magnecor 8.5 mm Racing Wires for
a '93 Legacy Turbo Wagon?
2. What do I need to pull codes from my OBD-1? I've
already got a Palm, so is there any software/cabling
that I can use or do I need a laptop?
Thanks Guys.
-Brian
__________________________________________________
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
Send FREE Holiday eCards from Yahoo! Greetings.
http://us.click.yahoo.com/IgTaHA/ZQdDAA ... /XoTolB/TM
Couple Questions...
Josh Colombo
Couple Questions...
The Magnecor wires you should be able to pick up at a speed shop. They'll order them specialty cut to your vehicle, as they do for every set of wires for magnecor. I have magnecor's website and contact info in the vendors section of my site, they probably have a dealer locater on there.
As for the codes, you can pull the codes on an OBD I without a computer. Check out my site under notes & tips. I have a detailed instructions on how to pull the ECU codes, what each code is for, and also have the instructions how to pull the TCU codes.
www.surrealmirage.com/subaru/subaru.html
Got any questions just holler.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com> **NEW**
of beats and rhythm" - ME
-----Original Message-----
Sent: Friday, December 21, 2001 5:17 PM
Subject: [BC-BFLegacyWorks] Couple Questions...
Thanks Guys.
-Brian
Do You Yahoo!?
Josh Colombo
Thanks Guys.
-Brian
Do You Yahoo!?
Rod Grosvenor
Couple Questions...
Brian-additional info: if you can find someone with what is similar to a Tech-I for the Subarus, you can not only pull codes but you can clear them w/o having to unhook your battery, etc. These are usually found in dealerships & are quite expensive. Just a thought.............ROD (AZ.)
----- Original Message -----
Sent: Friday, December 21, 2001 4:16 PM
Thanks Guys.
-Brian
Do You Yahoo!?
<http://rd.yahoo.com/M=215839.1778785.32 ... hoogroups2>
<http://us.adserver.yahoo.com/l?M=215839 ... =239580442>
Thanks Guys.
-Brian
Do You Yahoo!?
