Boost Issues...Solenoid Problems?
Subaru_Nation555
I recently installed a Saab 900 intercooler on my legacy. Everything was working fine until I started my car last night and it threw a check CEL. I have yet to check the code becasue the other green connector is stuck up in the other wiring but the code comes and goes. The car is acting like there is a boost leak so I took off the intercooler to eliminate that as a problem but it didn't seem to have an effect. I checked all the vacuum lines and everything looks in order. Sounds like it might be the boost control solenoid. Any suggestions?
Subaru_Nation555
If it's the original one, I'd probably replace it. The old style does have a tendancy to crack.
Subaru_Nation555
http://pa.partsandaccessories.com
has them for about 60 dollars for the oem and about 50 dollars for the bosch.
if you go to the dealership, better have your kidney removed ahead of time i'd imagine.
///M
'93 Legacy SS - part out
Subaru_Nation555
Subaru_Nation555
