Boost Issues...Solenoid Problems?
Subaru_Nation555
Post by Subaru_Nation555 »
I recently installed a Saab 900 intercooler on my legacy. Everything was working fine until I started my car last night and it threw a check CEL. I have yet to check the code becasue the other green connector is stuck up in the other wiring but the code comes and goes. The car is acting like there is a boost leak so I took off the intercooler to eliminate that as a problem but it didn't seem to have an effect. I checked all the vacuum lines and everything looks in order. Sounds like it might be the boost control solenoid. Any suggestions?
Splinter
Post by Splinter »
Use the black connectors to check the codes, the green connectors are to clear them
rallysam
Post by rallysam »
Well, a lot of things can make it run wrong. Get those codes and maybe we can help.
Subaru_Nation555
Checked the codes. 22-knock sensor. It seems to be acting normally now, the CEL is gone but the sensor is the original one. Think it should be replaced?
rallysam
Post by rallysam »
Only one code? That's a miracle :lol:
Well, if the code comes back, I guess you do have to replace it.
If it's the original one, I'd probably replace it. The old style does have a tendancy to crack.
Subaru_Nation555
What would a new one run from the dealer?
dzx
Post by dzx »
http://pa.partsandaccessories.com
has them for about 60 dollars for the oem and about 50 dollars for the bosch.
if you go to the dealership, better have your kidney removed ahead of time i'd imagine.
///M
'93 Legacy SS - part out
Subaru_Nation555
Thanks a lot.
MPtyza
Post by MPtyza »
I got my OEM knock sensor from 1stsubaruparts.com, for about $45 I believe. It's actually a Subaru dealership somewhere on the west coast
Subaru_Nation555
Also there seemed to be a lot of oil in the intercooler for it only being on for 150 miles.
