No more 2.2L (updated: Now image intensive)
JasonGrahn
Post by JasonGrahn »
-Jason Grahn
JasonGrahn
2.2L intake manifold doesn't fit! Funny thing is that the exhaust does though!
Gotta swap throttle bodies though! the 2.5L has a 3 wire idle control, legacy has a 4 wire.
Wiring from the engine has to be swapped to the 2.5L as well. Minimal work required from this - swap the plugs for the coil pack and the canister purge control solonoid.
coil plug being swapped: Image
the difference in throttle bodies:
-Jason Grahn
Sweet! You guys look like you're working very efficiently.
The throttle thing is actually the TPS... 1st-gens have idle switches and later ones don't.
What's the gold-colored stuff there? Gear oil?
legacy92ej22t
Post by legacy92ej22t »
Oh man, sorry to hear about the 2.2 Jason :( .
Wow, all that metal in the oils sure doesn't look good.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
Oh and nice pics by the way. Is that your shop?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Ohh... that's little tiny pieces of engine in the lubricant... Eegh.
What are you gonna do about the EGR stuff? Just cap it all off?
JasonGrahn
vrg3 wrote:Sweet! You guys look like you're working very efficiently.
That gold-colored stuff is my engine oil. Fun eh? Looks like gold-flake-metallic that i saw on a low-rider impala.
Mostly yeah, i've got a plate made for the big valve on the intake manifold. The other lines will be capped.
-Jason Grahn
JasonGrahn
Everything looks to mate up fairly well. Only problem i'm having now is getting the tranny to mate up with the engine. it's got about another inch and a half to go. Anyone have any tricks to ge tthe input shaft splines to align with the clutch and pilot bearing?
-Jason Grahn
Post by entirelyturbo »
Easy. Take a 22mm socket and turn the crank just a little bit. You should be able to slightly feel the clutch line up with the input shaft as you turn it.
2000 Subaru Legacy B4 RSK
*Formerly DerFahrer*
JasonGrahn
update (scroll down pause for effect):
It's ALIVE! Muhahahaha!!
wow, never realized how much more fun 30 extra foot lbs of torque is. Engine only threw --1-- code after plugging in a 2.5L DOHC into the 2.2L SOHC ECU. I was thinking it was going to be the cam angle sensor, but turns out that's just fine. It's the Air Control Valve (error 24). Gotta switch the two outer wires on the plug and it'll be peachy. also have to investigate my oil leak (believed to be rear main seal, easy solve, but time consuming), and it's done.
Not for the weak-hearted though. I'd give this swap a 7 out of 10 in terms of difficulty. With all the parts available this is easily a weekend task, but without them, and without the knowhow and support of friends then this could have turned out really hairy (like my back!! EW!)
Jake, I'm calling you dad's shop as soon as i wake up to schedule an appointment, hopefully today so i can cruise to the rally undaunted by engine leaks and error codes.
All your base are belong to ME!
-Jason Grahn
Awesome!
Are you trying to use the EJ25's IAC valve?
JasonGrahn
vrg3 wrote:Awesome!
Yes. In conjunction with the ej22 engine harness. The wires going into the plug are black, white w/stripe, and yellow (i can't recall correctly ATM). The two outside wires need to be switched. The engine is running in limp mode at the moment.
-Jason Grahn
Cool... I'm curious whether the EJ22 ECU can properly drive that type of IAC valve.
THAWA
Post by THAWA »
that's awesome jason, congrats :D
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
legacy92ej22t
Great to hear she's back on the road Jason.
So you can really tell a big difference in the power, huh?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
JasonGrahn
How about some pancakes? Bitch.
-Jason Grahn
ciper
Post by ciper »
Did you ever know that your my H E R O
I guess 30 extra HP isnt enough, you trying to get more power by disconnectiong the accessory belts :D
JasonGrahn
ciper wrote:Did you ever know that your my H E R O
Shaddup! ;) If i find 30 extra hp isn't enough, i could always do what my license plate tells me to do and RS-T. ;)
-Jason Grahn
czo79
Post by czo79 »
my....what a big engine you have.... :lol:
Huffer
Post by Huffer »
Jason - do you still have the pics for this around? I'm considering attempting the same thing...but having pics to look at prior would be a major confidence booster!
[size=84][url]http://www.lersoc.com[/url] / [url]http://www.sl-i.net[/url]
[b]98 Legacy BD - 178k and rusted out[/b] :([/size]
JasonGrahn
Yeah, I've got a CD with all the photos. Let me see if I can track it down.
-Jason Grahn
Huffer
Post by Huffer »
Much appreciated! :D
I'm doing auto to auto - will that make things easier?
JasonGrahn
dunno.
-Jason Grahn
Shouldn't really matter regarding the trans type as long as you keep the TCU happy.
So that may depend on what ECU you plan to use.
If you're using the stock ECU, it'll be easier to not have a 90-91 5-speed, because the IAC valve will already be of the correct type.
