Moderators: Helpinators , Moderators
JasonGrahn
Posts: 1333 Joined: Tue Oct 15, 2002 4:55 pm
Post
by JasonGrahn » Fri Feb 27, 2004 11:46 pm
-Jason Grahn
JasonGrahn
Post
by JasonGrahn » Fri Feb 27, 2004 11:49 pm
2.2L intake manifold doesn't fit! Funny thing is that the exhaust does though!
Gotta swap throttle bodies though! the 2.5L has a 3 wire idle control, legacy has a 4 wire.
Wiring from the engine has to be swapped to the 2.5L as well. Minimal work required from this - swap the plugs for the coil pack and the canister purge control solonoid.
coil plug being swapped:
the difference in throttle bodies:
-Jason Grahn
Posts: 12517 Joined: Sun Nov 03, 2002 2:13 am
Post
by vrg3 » Sat Feb 28, 2004 12:04 am
Sweet! You guys look like you're working very efficiently.
The throttle thing is actually the TPS... 1st-gens have idle switches and later ones don't.
What's the gold-colored stuff there? Gear oil?
legacy92ej22t
Posts: 5203 Joined: Thu Nov 07, 2002 3:59 am
Post
by legacy92ej22t » Sat Feb 28, 2004 12:13 am
Oh man, sorry to hear about the 2.2 Jason
Wow, all that metal in the oils sure doesn't look good.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
Post
by legacy92ej22t » Sat Feb 28, 2004 12:16 am
Oh and nice pics by the way. Is that your shop?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Post
by vrg3 » Sat Feb 28, 2004 12:21 am
Ohh... that's little tiny pieces of engine in the lubricant... Eegh.
What are you gonna do about the EGR stuff? Just cap it all off?
JasonGrahn
Post
by JasonGrahn » Sat Feb 28, 2004 12:23 am
vrg3 wrote: Sweet! You guys look like you're working very efficiently.
That gold-colored stuff is my engine oil. Fun eh? Looks like gold-flake-metallic that i saw on a low-rider impala.
Mostly yeah, i've got a plate made for the big valve on the intake manifold. The other lines will be capped.
-Jason Grahn
JasonGrahn
Post
by JasonGrahn » Thu Mar 04, 2004 8:26 am
Everything looks to mate up fairly well. Only problem i'm having now is getting the tranny to mate up with the engine. it's got about another inch and a half to go. Anyone have any tricks to ge tthe input shaft splines to align with the clutch and pilot bearing?
-Jason Grahn
Posts: 6000 Joined: Thu Dec 05, 2002 7:06 pm
Post
by entirelyturbo » Thu Mar 04, 2004 8:38 am
Easy. Take a 22mm socket and turn the crank just a little bit. You should be able to slightly feel the clutch line up with the input shaft as you turn it.
*Formerly DerFahrer*
@entirelyturbo on social media, including
Facebook ,
Instagram ,
Twitter , and
TikTok
JasonGrahn
Post
by JasonGrahn » Fri Mar 05, 2004 10:25 am
update (scroll down pause for effect):
It's ALIVE! Muhahahaha!!
wow, never realized how much more fun 30 extra foot lbs of torque is. Engine only threw --1-- code after plugging in a 2.5L DOHC into the 2.2L SOHC ECU. I was thinking it was going to be the cam angle sensor, but turns out that's just fine. It's the Air Control Valve (error 24). Gotta switch the two outer wires on the plug and it'll be peachy. also have to investigate my oil leak (believed to be rear main seal, easy solve, but time consuming), and it's done.
Not for the weak-hearted though. I'd give this swap a 7 out of 10 in terms of difficulty. With all the parts available this is easily a weekend task, but without them, and without the knowhow and support of friends then this could have turned out really hairy (like my back!! EW!)
Jake, I'm calling you dad's shop as soon as i wake up to schedule an appointment, hopefully today so i can cruise to the rally undaunted by engine leaks and error codes.
All your base are belong to ME!
-Jason Grahn
Post
by vrg3 » Fri Mar 05, 2004 3:37 pm
Awesome!
Are you trying to use the EJ25's IAC valve?
JasonGrahn
Post
by JasonGrahn » Fri Mar 05, 2004 4:26 pm
vrg3 wrote: Awesome!
Yes. In conjunction with the ej22 engine harness. The wires going into the plug are black, white w/stripe, and yellow (i can't recall correctly ATM). The two outside wires need to be switched. The engine is running in limp mode at the moment.
-Jason Grahn
Post
by vrg3 » Fri Mar 05, 2004 4:55 pm
Cool... I'm curious whether the EJ22 ECU can properly drive that type of IAC valve.
THAWA
Posts: 6829 Joined: Thu Aug 21, 2003 7:44 pm
Post
by THAWA » Fri Mar 05, 2004 4:57 pm
that's awesome jason, congrats
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
legacy92ej22t
Post
by legacy92ej22t » Fri Mar 05, 2004 5:02 pm
Great to hear she's back on the road Jason.
So you can really tell a big difference in the power, huh?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
JasonGrahn
Post
by JasonGrahn » Fri Mar 05, 2004 7:16 pm
How about some pancakes? Bitch.
-Jason Grahn
ciper
Posts: 4388 Joined: Tue Oct 15, 2002 8:16 pm
Post
by ciper » Fri Mar 05, 2004 8:06 pm
Did you ever know that your my H E R O
I guess 30 extra HP isnt enough, you trying to get more power by disconnectiong the accessory belts
JasonGrahn
Post
by JasonGrahn » Fri Mar 05, 2004 8:09 pm
ciper wrote: Did you ever know that your my H E R O
Shaddup!
If i find 30 extra hp isn't enough, i could always do what my license plate tells me to do and RS-T.
-Jason Grahn
czo79
Posts: 466 Joined: Mon Jan 20, 2003 9:11 am
Post
by czo79 » Sat Mar 06, 2004 8:32 am
my....what a big engine you have....
Huffer
Posts: 6 Joined: Thu Jan 12, 2006 6:07 pm
Post
by Huffer » Thu Jan 12, 2006 7:57 pm
Jason - do you still have the pics for this around? I'm considering attempting the same thing...but having pics to look at prior would be a major confidence booster!
[size=84][url]http://www.lersoc.com[/url] / [url]http://www.sl-i.net[/url]
[b]98 Legacy BD - 178k and rusted out[/b] :([/size]
JasonGrahn
Post
by JasonGrahn » Thu Jan 12, 2006 8:30 pm
Yeah, I've got a CD with all the photos. Let me see if I can track it down.
-Jason Grahn
Huffer
Post
by Huffer » Thu Jan 12, 2006 8:31 pm
Much appreciated!
I'm doing auto to auto - will that make things easier?
JasonGrahn
Post
by JasonGrahn » Thu Jan 12, 2006 8:35 pm
dunno.
-Jason Grahn
Posts: 27930 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Fri Jan 13, 2006 1:53 am
Shouldn't really matter regarding the trans type as long as you keep the TCU happy.
So that may depend on what ECU you plan to use.
Post
by vrg3 » Fri Jan 13, 2006 3:52 am
If you're using the stock ECU, it'll be easier to not have a 90-91 5-speed, because the IAC valve will already be of the correct type.
