Sti Front and Rear Swaybars fit?
livestrong14
Post by livestrong14 »
Hey again guys,
Do stock STi front and rear sway bars fit on a 91' legacy turbo? I have heard that the rear sway requires a little modding to the spare tire area. I have also heard that the front sway is a direct bolt on. Does anybody know for sure? I think Kelly is using this setup.
Thanks,
-Devan
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
livestrong14
Is there anybody out there that knows? I would really like to find out by this week.
Thanks,
-Devan
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
The front will probably be a tad wider, but can probably be made to work.
The rear....I don't know.
livestrong14
does anybody know someone that has already done this? I could PM them and get the whole scoop.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Imprezive
Post by Imprezive »
I doubt the rear will fit without modification. As for the front I dont know, have you tried searching?
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
livestrong14
yea, I've searched quite a bit.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
jamal
Vendor
Vendor
Post by jamal »
As far as I know they don't. Hardy (THAWA) has various STi suspension parts, as has psyber_0ptix on nasioc. You should try a search on nasioc and include their names.
Kelly
Post by Kelly »
I replied to your PM Devan.
Now that I think about it, I think there both the same size, only a bit wider and will rub your tires if your running a 225 in the rear. Its kinda been a while since I actually got under my car. :(
Imprezive
Post by Imprezive »
I think I remember a guy installing a wrx rear bar and it was super close to the tires, aside from that he had to cut that bump off the bottom of the spare tire holder. I'm going to work on making sway bar mounts to enable the use of wrx/ipreza bars without modification
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
livestrong14
rallitektech wrote:I replied to your PM Devan.
Thanks kelly! I just replied to your PM. I'll stop by the shop as soon as we get finished up. Take care
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Adam West
Post by Adam West »
Reserrecting this...What about the FRONT swaybar? Will the STI bar fit?
The reason I'm asking is that Teagues sells a monster 27mm adjustable Whiteline "Racing" front sway bar for STI's...thinking it might be nice to get...
VRoman
Post by VRoman »
Does anyone know if a WRX front sway bar fits a 94 Legacy? I am trying to find an adjustable 24mm sway bar, but it seems like no one makes them any bigger than 22 for an older Legacy like mine.
Post by entirelyturbo »
You can use a WRX/STi front bar if you use the WRX/STi front control arms.
Not only is the front track wider on the WRX/STi, but the front swaybar mounts differently than ours does.
Oh, and if you use WRX/STi front control arms, you have to change the front bushing. The WRX/STi bushing won't fit in our crossmember.
*Formerly DerFahrer*
n2x4
Post by n2x4 »
I thought all the control arms were the same? When I replaced my broken one with one from a junkyard they gave me a control arm from a 97 legacy and it fit fine.
SUBARUEHS Racing
A 97 Legacy one will fit. The part number for ALL 1st and 2nd gen Legacies, 90-99, are all the same.
But the newer cars are different.
