Sti Front and Rear Swaybars fit?
livestrong14
Hey again guys,
Do stock STi front and rear sway bars fit on a 91' legacy turbo? I have heard that the rear sway requires a little modding to the spare tire area. I have also heard that the front sway is a direct bolt on. Does anybody know for sure? I think Kelly is using this setup.
Thanks,
-Devan
Thanks,
-Devan
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
livestrong14
Is there anybody out there that knows? I would really like to find out by this week.
Thanks,
-Devan
Thanks,
-Devan
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
The front will probably be a tad wider, but can probably be made to work.
The rear....I don't know.
livestrong14
does anybody know someone that has already done this? I could PM them and get the whole scoop.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
livestrong14
I think I remember a guy installing a wrx rear bar and it was super close to the tires, aside from that he had to cut that bump off the bottom of the spare tire holder. I'm going to work on making sway bar mounts to enable the use of wrx/ipreza bars without modification
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
livestrong14
Thanks kelly! I just replied to your PM. I'll stop by the shop as soon as we get finished up. Take carerallitektech wrote:I replied to your PM Devan.
Now that I think about it, I think there both the same size, only a bit wider and will rub your tires if your running a 225 in the rear. Its kinda been a while since I actually got under my car.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Reserrecting this...What about the FRONT swaybar? Will the STI bar fit?
The reason I'm asking is that Teagues sells a monster 27mm adjustable Whiteline "Racing" front sway bar for STI's...thinking it might be nice to get...
- quasi-mod-o
You can use a WRX/STi front bar if you use the WRX/STi front control arms.
Not only is the front track wider on the WRX/STi, but the front swaybar mounts differently than ours does.
Oh, and if you use WRX/STi front control arms, you have to change the front bushing. The WRX/STi bushing won't fit in our crossmember.
- quasi-mod-o
