Changing IAC
TurboSubie
Changing IAC
Ok, so I started to take off the IAC..the top two bolts on the side came out easily. how do you get to the bottom two? I am completely confused as to how you get the bottom two out?
1994 Aegian Blue Subaru Legacy Sport Sedan. Mean Muggin.
1995 Honda CBR 600 F3 D&D complete system,K&N, few other things..
TurboSubie
TurboSubie
TurboSubie
douglas vincent
The IAC is 4 10mm head bolts. Two on top, two on the bottom. There are many different IACs themselves, but the bolt pattern is always the same.
TurboSubie
douglas vincent
You may have to pull the coupler off the block that comes straight up and into the PCV tubing system. And swear a little.
TurboSubie
tris91ricer
- Title Whore
Did this a few weeks back. On NA cars, its cake. Unfortunately, our turbo gets in the way. . .
There are two 12mm bolts that can come off the turbo side nearest the iac. Don't be afraid, you can pull these to get at everything else. Make sure you've got plenty of ratchet extensions and patience, and the bottom two will come out just fine.
Lmk if you need more help, bro.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
