Changing IAC
TurboSubie
Changing IAC
Post by TurboSubie »
Ok, so I started to take off the IAC..the top two bolts on the side came out easily. how do you get to the bottom two? I am completely confused as to how you get the bottom two out?
1994 Aegian Blue Subaru Legacy Sport Sedan. Mean Muggin.
1995 Honda CBR 600 F3 D&D complete system,K&N, few other things..
TurboSubie
bump..any ideas?
TurboSubie
TurboSubie
douglas vincent
Post by douglas vincent »
The IAC is 4 10mm head bolts. Two on top, two on the bottom. There are many different IACs themselves, but the bolt pattern is always the same.
TurboSubie
yeah, I got the two top ones out..do I need to take anything off to access the bottom bolts? I'm having a heck of a time getting to them
douglas vincent
You may have to pull the coupler off the block that comes straight up and into the PCV tubing system. And swear a little.
quicklook
Post by quicklook »
or maybe swear a lot and wish you had smaller hands.
TurboSubie
that may work, if not Im cutting my fingers in half! heh
tris91ricer
Title Whore
Post by tris91ricer »
Did this a few weeks back. On NA cars, its cake. Unfortunately, our turbo gets in the way. . .
There are two 12mm bolts that can come off the turbo side nearest the iac. Don't be afraid, you can pull these to get at everything else. Make sure you've got plenty of ratchet extensions and patience, and the bottom two will come out just fine.
Lmk if you need more help, bro.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
