turbo vs NA exhaust...
spdracr
Post by spdracr »
I know the header/up-pipe/down-pipe are different but what about after the cats? Are they the same as far as mounting goes. The turbo's have a 2.5" pipe so i'm thinking it would be an upgrade over my stock "L" exhaust, but I could also be wrong which is why i'm asking.
thanks
-ben
The mounts and everything should be the same.
BAC5.2
Post by BAC5.2 »
The turbo's don't have a 2.5" pipe.
spdracr
Post by spdracr »
so is there any reason to switch to a turbo exhaust? just looking for cheap power gains for my 92...
-bt
scuzzy
Post by scuzzy »
spdracr wrote:so is there any reason to switch to a turbo exhaust? just looking for cheap power gains for my 92...
-bt
you have a 92 NA?
you can't use the turbo exhaust, and they're both 2.25", you need the turbocharger plus a bunch of other supporting mods.
#82 M4 TRSCCA Rallycross
spdracr
Post by spdracr »
cool.. thanks..
subytech
Post by subytech »
Theres a guy running around town here that has a stock cat back STi exhaust on his 92 sedan, looks great fits great and sounds great!
Post by 555BCTurbo »
-bt
you have a 92 NA?
NA exhaust is 2 inch
spdracr
Post by spdracr »
so from teh cat back could i use a turbo exhaust and get some gains?
livestrong14
Post by livestrong14 »
Nick is correct. The N/A's have a 2 inch exhaust.
If I were you, I would just pick up a Stock STi catback. As previously stated it looks and sounds great!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
spdracr
Post by spdracr »
hmm, thats an idea.. any one know if it just bolts up or will i have to take it to a shop and get it "loved" on?
Definately not a direct fit...
Honestly, the most gains exhaust wise would be to go full cat delete and a straight through muffler...
spdracr
Post by spdracr »
damn any thing that is more of a direct fit? maybe a turbo exhaust would be best, from the cat back at least.. 2.25 vs 2.0 and they are pretty cheap...
n2x4
Post by n2x4 »
Any particular reasons you want to upgrade the entire exhaust system on your L?
Unless you have other supporting mods, I don't think you'll see any real performance gains. I'm not saying don't do it, but I'd save a few bucks and just get a nice muffler with a nice sound.
I just cut my stock muffler out, saved the 2 end hangers, and welded on a Summit turbo cheapo muffler. It actually sounds pretty good and has a decent rumble. Not as deep as my greddy on my other subaru, but good nonetheless. The muffler itself was only 15 bucks, so you might want to start there.
SUBARUEHS Racing
spdracr
Post by spdracr »
well, my future plans are for a header and i was looking for a more free flowing system. trying to squeeze everything i can from the 2.2, i was hoping there was something easy that i could swap over. still learning these 1st gens..
-ben
BAC5.2
Post by BAC5.2 »
How loud is the STi catback on the EJ22?
I might go this route on my Forester, just for a nicer looking exhaust, and the design of the Forester exhaust is dumb. It droops down in the middle after the cat for no reason whatsoever. I scrape it all of the time when offroading.
livestrong14
It will be very similar to stock in terms of DB output. People do it for the throaty rumble!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
BAC5.2
Post by BAC5.2 »
Hmm, I might do it then!
BXSS
Post by BXSS »
I also used a cheap-o ($15-20) summit racing 3" turbo muffler when my 3" TBE was made. I must admitt that I did not expect much from the muffler other than a stealth appearance, but it sounds very good, & the exhaust system as a whole made an obvious difference in performance.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
