turbo vs NA exhaust...
I know the header/up-pipe/down-pipe are different but what about after the cats? Are they the same as far as mounting goes. The turbo's have a 2.5" pipe so i'm thinking it would be an upgrade over my stock "L" exhaust, but I could also be wrong which is why i'm asking.
thanks
-ben
thanks
-ben
The mounts and everything should be the same.
you have a 92 NA?spdracr wrote:so is there any reason to switch to a turbo exhaust? just looking for cheap power gains for my 92...
-bt
you can't use the turbo exhaust, and they're both 2.25", you need the turbocharger plus a bunch of other supporting mods.
#82 M4 TRSCCA Rallycross
Theres a guy running around town here that has a stock cat back STi exhaust on his 92 sedan, looks great fits great and sounds great!
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
scuzzy wrote:you have a 92 NA?spdracr wrote:so is there any reason to switch to a turbo exhaust? just looking for cheap power gains for my 92...
-bt
NA exhaust is 2 inch
livestrong14
Nick is correct. The N/A's have a 2 inch exhaust.
If I were you, I would just pick up a Stock STi catback. As previously stated it looks and sounds great!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Any particular reasons you want to upgrade the entire exhaust system on your L?
Unless you have other supporting mods, I don't think you'll see any real performance gains. I'm not saying don't do it, but I'd save a few bucks and just get a nice muffler with a nice sound.
I just cut my stock muffler out, saved the 2 end hangers, and welded on a Summit turbo cheapo muffler. It actually sounds pretty good and has a decent rumble. Not as deep as my greddy on my other subaru, but good nonetheless. The muffler itself was only 15 bucks, so you might want to start there.
SUBARUEHS Racing
How loud is the STi catback on the EJ22?
I might go this route on my Forester, just for a nicer looking exhaust, and the design of the Forester exhaust is dumb. It droops down in the middle after the cat for no reason whatsoever. I scrape it all of the time when offroading.
livestrong14
It will be very similar to stock in terms of DB output. People do it for the throaty rumble!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
I also used a cheap-o ($15-20) summit racing 3" turbo muffler when my 3" TBE was made. I must admitt that I did not expect much from the muffler other than a stealth appearance, but it sounds very good, & the exhaust system as a whole made an obvious difference in performance.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
