Anyone not have ABS?
So 25 unsprung weight is too light if you remove all. What's someone else's best guess?
Splinter, when you get done can we trouble you to jump on a scale holding a box of that stuff?
Pretty much all automotive publications have proven ABS does help stop faster in a straight line, whether it be in the dry or wet. Humans cannot regulate brake force nearly as fast as a computer can, especially near the threshold of lockup.jamal wrote:
ABS does not make a car stop in a shorter distance.
The purpose of ABS is not primarily to stop the car in a shorter distance. The goal is to keep the car in control.93forestpearl wrote:Pretty much all automotive publications have proven ABS does help stop faster in a straight line, whether it be in the dry or wet. Humans cannot regulate brake force nearly as fast as a computer can, especially near the threshold of lockup.jamal wrote:
Halfway decent threshold braking will stop shorter than abs. Someone who can't do any better than to mash the brake pedal shouldn't be driving.
Oh, so we've gone from "all automotive publications" to sport compact car. Last I checked that magazine is one big rice catalog filled with inaccurate information.
Regardless, this isn't the topic and if you want to discuss it further I suggest you start a new thread. Or at least read something other than SCC.
SemperGuard
Manarius
If insurance companies are willing to give discounts to people who have ABS on their cars, it must be a good safety feature...
ABS = anti-lock braking system...
Not distance but control. You can turn while braking to avoid objects...
Threshold braking is not as effective on uneven pavement. ABS isn't as effective in gravel or snow.
SemperGuard
All_talk
Yep, One MC output to both fronts, the other to your adjustable prop valve, then split to both rears.
I'm thinking that I might leave the ABS in mine, with a switch to turn it on/off, then just install two adj. prop. valves in the cabin in place of the stock ones. As long as you set them the same should work just fine (maybe you could do some fun stuff turn brake style with this setup). Best of both worlds, on demand.
Gary
Gary
