PICs and Numbers from my visit to the Dyno
macipusy
Post by macipusy »
I just got back from a shop that has a dyno....I took some pics, as best as I could....they make you stand outside the bay. I snuck a couple from the inside....hehe
Here is my one month old to me 91 SS with the following engine performance mods....
LW Pulley set
TBE-Invidia 3” bellmouth catless DP, Borla 2.5” CBE - 4” singletip
Custom straight Intake with ‘mug shot’ and JC sports cone filter
Hallman MBC
Ground Mod
Max Power: 177.7 AWHp @ 5400 RPM
Peak Torque: 198.4 ft-lb @ 3900 RPM
The guy at the shop was like....wow, I am surprised at these numbers.....especially since stock WRX is like 160 awhp
http://i212.photobucket.com/albums/cc30 ... G_4286.jpg
http://i212.photobucket.com/albums/cc30 ... G_4288.jpg
http://i212.photobucket.com/albums/cc30 ... G_4291.jpg
http://i212.photobucket.com/albums/cc30 ... G_4272.jpg
http://i212.photobucket.com/albums/cc30 ... G_4293.jpg
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
92ss satinsvoice
Post by 92ss satinsvoice »
that perdy good. how much boost are you running?
i wonder what i would get at the wheels.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
tsbpenguin
Post by tsbpenguin »
Looking good and nice numbers. Where in CO are you? I'm in Lafayette (east of boulder)
Keep up the good work
In between Subies
macipusy
Post by macipusy »
I'm in North Denver....Highlands/Sloan Lake....slightly east of Sheridan Blvd on 26th... :-)
maciek puszynski
16 WRX | 6mt | fa20
macipusy
Post by macipusy »
I know what you mean 92SS....I was going mad to know what it wasfor sure. I was telling people that estimated hp was like 230-250 chp...dependong on my mood for psi....12-14ish
The responses were usuaally laughs and smirks.....
Now I got paper proof...I will scan my printouts and post them for analysis... :-)
maciek puszynski
16 WRX | 6mt | fa20
tsbpenguin
Cool cool what shop is that at?
And did you have them correct the numbers for elevation?
In between Subies
macipusy
Post by macipusy »
Shouldn't they be correct numbers.....I was guessing 230 chp before I got on the dyno.....pretty, pretty good....pretty good...
maciek puszynski
16 WRX | 6mt | fa20
TheSubaruJunkie
Post by TheSubaruJunkie »
isnt a stock WRX closer to 220hp stock?
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
tsbpenguin
Yes stock wrx is 230hp... to the crank. Not to the wheels.
Macipusy they may or may not be adjusted. I'd ask the shop that dyno'd you and ask them. If not have them adjust the numbers for sea level because it gives you a better knowledge base to know what you'd compare to.
In between Subies
asc_up
Post by asc_up »
kinda reviving this thread.
so macipusy, you said you're running ~12 psi. is that on the stock turbo and no intercooler?
92ss satinsvoice
i was running around, 10-12 psi with no intercooler but i only run premium fuel. was fun, till the clutch decided to not want to hold the power anymore.
Andy
94 L n/a 5spd, Rip
asc_up
Post by asc_up »
hmmm ok. i'm just asking because i have an 06 wrx intercooler but i was planning on installing it after i get my new turbo. BUT i'd still like to run more than stock boost.
i've read numerous posts where some people say they run 12 psi just fine and then others say that running much more than 10 psi w/o an intercooler is dangerous and can cause detonation and what not.
so is there a definite answer to this?
It definitely depends.
asc_up
Post by asc_up »
beatersubi wrote:It definitely depends.
on?
let me ask this: can i run ~11psi on the VF11 with a 3" TBE, using only 92+ octane fuel but w/o an intercooler SAFELY?
Depends on: the fuel system, engine management, milage and the overall condition of the motor.
Do you have a way to monitor AFR's?
Personally, I'd install the i/c before turning up the boost. Especially on a higher milage stock motor.
NICO
Post by NICO »
a white legacy turbo, its like a drug.
nice car bye the way.
NICO
Post by NICO »
Post by 555BCTurbo »
Ok...I will put the "how much boost, etc" inquiries to rest...
Running anything more than 10psi w/o intercooler is not a good idea...in fact, in my personal opinion, running anything over stock boost without a charge cooler is a bad idea.
The VF11 runs out of efficiency right around 12psi...so, running it any higher will just heat up the engine and your intercooler and not really make more power
Just intercool it...with the low cost of WRX intercoolers these days, you are silly not to!
asc_up
Post by asc_up »
ok. thanks for the info nick!!
