PICs and Numbers from my visit to the Dyno
I just got back from a shop that has a dyno....I took some pics, as best as I could....they make you stand outside the bay. I snuck a couple from the inside....hehe
Here is my one month old to me 91 SS with the following engine performance mods....
LW Pulley set
TBE-Invidia 3” bellmouth catless DP, Borla 2.5” CBE - 4” singletip
Custom straight Intake with ‘mug shot’ and JC sports cone filter
Hallman MBC
Ground Mod
Max Power: 177.7 AWHp @ 5400 RPM
Peak Torque: 198.4 ft-lb @ 3900 RPM
The guy at the shop was like....wow, I am surprised at these numbers.....especially since stock WRX is like 160 awhp
http://i212.photobucket.com/albums/cc30 ... G_4286.jpg
http://i212.photobucket.com/albums/cc30 ... G_4288.jpg
http://i212.photobucket.com/albums/cc30 ... G_4291.jpg
http://i212.photobucket.com/albums/cc30 ... G_4272.jpg
http://i212.photobucket.com/albums/cc30 ... G_4293.jpg
LW Pulley set
Hallman MBC
Ground Mod
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
92ss satinsvoice
that perdy good. how much boost are you running?
i wonder what i would get at the wheels.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
94 L n/a 5spd, Rip
tsbpenguin
I'm in North Denver....Highlands/Sloan Lake....slightly east of Sheridan Blvd on 26th...
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
I know what you mean 92SS....I was going mad to know what it wasfor sure. I was telling people that estimated hp was like 230-250 chp...dependong on my mood for psi....12-14ish
The responses were usuaally laughs and smirks.....
Now I got paper proof...I will scan my printouts and post them for analysis...
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
tsbpenguin
Shouldn't they be correct numbers.....I was guessing 230 chp before I got on the dyno.....pretty, pretty good....pretty good...
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
TheSubaruJunkie
tsbpenguin
92ss satinsvoice
i was running around, 10-12 psi with no intercooler but i only run premium fuel. was fun, till the clutch decided to not want to hold the power anymore.
Andy
94 L n/a 5spd, Rip
94 L n/a 5spd, Rip
hmmm ok. i'm just asking because i have an 06 wrx intercooler but i was planning on installing it after i get my new turbo. BUT i'd still like to run more than stock boost.
i've read numerous posts where some people say they run 12 psi just fine and then others say that running much more than 10 psi w/o an intercooler is dangerous and can cause detonation and what not.
so is there a definite answer to this?
Depends on: the fuel system, engine management, milage and the overall condition of the motor.
Do you have a way to monitor AFR's?
Personally, I'd install the i/c before turning up the boost. Especially on a higher milage stock motor.
Ok...I will put the "how much boost, etc" inquiries to rest...
Running anything more than 10psi w/o intercooler is not a good idea...in fact, in my personal opinion, running anything over stock boost without a charge cooler is a bad idea.
The VF11 runs out of efficiency right around 12psi...so, running it any higher will just heat up the engine and your intercooler and not really make more power
Just intercool it...with the low cost of WRX intercoolers these days, you are silly not to!
