Pressure Plate to Flywheel bolts?
skid542
Post by skid542 »
This may a bit of a noob question but... my new flywheel and clutch arrived today (along with my Grp N mounts - woot :)) and it occured to me, do I need to source a set of bolts to mate the pressure plate to the flywheel. It's been a while since I pulled my parts car apart and I can't remember if I'll get the bolts I need from taking off the flexplate?
I know the bolts from the flex plate to the crank will be re-used for the flywheel to the crank, but with the other bolts work for the pressure plate to the crank?
Simple question I know, but I didn't want to get caught on this with my pants down so to speak.
And while I have your attention... are all the thread sizes on the slave and master cylinders the same? i.e. I need to get a hose to join the two and want to get a braided line and am not sure what length and fittings I need at the end.
Thank you in advance.
Lee
You will need the bolts to bolt the PP to the flywheel.
skid542
Post by skid542 »
Care to provide any info such as bolt dia. and pitch?
Or a step better, P/N?
Thanks.
Lee
skid542
Post by skid542 »
Mods, I now have this information and have added it to my other all inclusive thread on my swap.
Please delete this thread.
Lee
For archival purposes, here's a link to information answering original question.
http://bbs.legacycentral.org/viewtopic. ... 451#282451
