»  BC-BF Legacy Discussion »  Electrical
#Electrical Compilation Thread Sticky
Custom Search
Login | Register
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Electrical Compilation Thread Sticky
PostPosted: Sun Nov 01, 2009 10:46 pm
How to read Check Engine Light Codes
Legacy Turbo ECU Pinout Diagram Needed
First Gen Turbo Legacy ECU I/O Spreadsheet
An ECU scan tool for turbo and NA owners
Alarm/Remote Starter wiring info UPDATE #2
My new project -- a standalone scan tool (lots of pictures)
Factory plug fix
THE EJ20G ECU Thread
How to read the codes from auto seatbelt computer
EJ20G "RobTune" Info
Rob's 4to2 Igntion Converter
3 wire to 2 wire alternator plug conversion info
Radio Wire Diagram
Behind Dash Relay Location Guide With Pictures!
Reading Electrical Connector Diagrams & Pin Numbering
Variable Intermittent Wiper Upgrade - DIY with pictures
How-To: Convert To GD WRX Coil On Plug w/EJ20G ECU
Apexi AVC-R install
Select Monitor or Scan Tool Check Sheet
Electronic Legacy gauge cluster into a US Legacy
Shielded Wire Replacement
Alternative ECU Patch/Test Harness Options
1997 Impreza OBS
Profile  Offline
 Post subject:
PostPosted: Mon Nov 02, 2009 1:33 am
Great idea!! I refer to the engine forum on all the time.
Taking suggestions?
I seem to refer tons of folks from other forums to these two threads of mine. Maybe the sticky would be a good place to flag them?
"Need electronics help", the thread where we outlined if it was poosible to run a 4 channel ECU with the factory harness.
viewtopic.php?t=35093
And the eventual "how-to" thread. However, upon re-reading it, it could use some clarification. I'll try working on it if there is enough interest.
viewtopic.php?t=37071
Profile  Offline
 Post subject:
PostPosted: Mon Nov 02, 2009 4:31 am
Let me know when you're happy with the threads, I will add to the sticky post.
1997 Impreza OBS
Profile  Offline
 Post subject: Re: Electrical Compilation Thread Sticky
PostPosted: Tue Sep 29, 2015 6:11 pm
Perhaps SAFC settings and info would be good to add? Considering it's the most commonly used and easiest to operate air/fuel controller.
Profile  Offline
PostPosted: Thu Sep 29, 2016 11:05 pm
Hi GarageBuilt, I am not aware of any current members (besides yourself) who are using it. If you want to create a thread on the ins and outs, installation, tuning and results, I can ask the administrator if we can add it to the sticky.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 6 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
