I bought a set of '04 STi 550 yellow tops in prep for some kind of EM.
Question 1:
Has anyone used Carl Davey's adaptor kits to fit 550's to their EJ22T fuel rails?
http://www.carldavey.co.uk/product.php?id=2
Carl says that the adaptors work "if the grey top 440's are a direct fit the rail, then the adaptors will work"
I would like to do this so I could revert back to the stock 370 (or 390, or whatever they are) stock pink-top injectors later if need be. This would notbe possible if I swapped to the NA rails.
Question 2:
The 550's I bought do not have pintle caps on them. Do I need these...I expect that I DO need them (regardless if I use the adaptors or the NA rails).
I'll probably send these off to whichhunter for cleaning/flow.new o-rings, and he'll replace the caps too. Just looking for input.
Thanks,
Chad
STi 550's in Turbo rails - adaptor kit?
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
Here is another set of adapters. You don't have to go to UK to get some.
http://www.deatschwerks.com/catalog/pro ... cts_id=194
Mine.
![Image](http://gallery.legacycentral.org/d/14924-2/IMG_1170.JPG)
Mine.
Ah interesting solution. Will keep in mind for upgrades if I ever get my car running properly.
With all my recent injector o-ring leaking issues, I wonder how much more prone this makes the whole setup to leaks...
'11 WRX Limited
'94 TW | R.I.P.
Thanks all.
Klienkid, the DW kit looks like the same basic design as the UK kit, except it contains some unnecessary (for our application) connectors.
Did you use any other o-rings besides the 2 oem's on the new injector and the 3rd o-ring on the machined adaptor? (3 total per injector) No o-ring spacers like the 440 injectors need (?).
In the end it looks like either kit will work, and the UK kit is only $50.
