Bushings
SubyFusion
Bushings
where is a good place to find Transmission Cross Member Bushings, and Differential Bushings online for a good price I can't seem to find any!
1992 Legacy L (AWD )(5MT)[2.5RS Trans] EJ22T Swap in Progress
subaru_styles
Re: Bushings
turn in concepts
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
1994 turbo wagon
SubyFusion
SubyFusion
Re: Bushings
Is there a place that I can get some Stiffer bushings for the diff?
Re: Bushings
I think you can probably get some from TiC, kartboy, whiteline, or superpro.
Not all of them may have one, but one of them probably has it. Our diffs use a bracket and the bracket has metal collared bushings. They are a pain to remove! If you can find replacement bushings, hopefully they are just poly bushings you can install by hand.
If all you can find is the hardened rubber STi/group N bushings, I wouldn't bother. That's kind of why I didn't replace my rear diff bushing a couple years back. All I could readily get was the STi bushings, and they are a living pain in the arse to replace.
SubyFusion
Re: Bushings
I bought some Kartboy outrigger Bushings thinking they would fit when I did my swap, but the top Bushings didn't work so I still haven't put them on. I bought them from TIC
Re: Bushings
The kartboy outrigger bushings should work. I've got them on my Legacy. They are kind of confusing on how to install though.
SubyFusion
Re: Bushings
The smaller ones work but I cant figure out the larger ones!
Re: Bushings
They just go between the body and outrigger.....they just kind of sit there.
This is assuming they're anything like the whiteline outrigger bushings.
Any chance you could snap some pics?
