Running Supppppppper Rich WOT
darkcrave
Post by darkcrave »
I was run running 10.1 sometimes during idle, other times it would idle 15.1.
Under WOT, AFR would drop 9.1 and the car would bog down.
Only under WOT, normal driving was fine
Tonight i Cleaned my MAF, Plugs and clean my O2 connectors. Now the car is idling 15-16.1. But under WOT the AFR will drop extremely rich.
Listen to the engine under WOT.
**At 7secs in the video, i had my foot all the way on the gas, the car completely stop accelerating
TD05H
Jecs
RobTune/Converter
MBC 18psi
apexi intake
I have tired 3 coils ( MSD on currently )
BPV going back into the intake
Tune
TMIC
Fuel
Taillight
Redlined
Re: Running Supppppppper Rich WOT
Post by Redlined »
might be time to upgrade to a JEKS MAF. when I was running the stock MAF Angel would suddenly go rich when the Turbo spooled, My thoughs on the matter, once the MAF hits its max read instead of stopping fuel where it is it signals all open.
Just my 2c. not sure if this helps but it was my experience after PRE replaced my JEKS with a OEM MAF without my permission.
darkcrave
Post by darkcrave »
Sorry i should have posted
This is with
TD05H
Jecs
RobTune/Converter
Tune
TMIC
Fuel
Taillight
Redlined
Post by Redlined »
make sure the blue wire to your MAF is grounded to body... all I can think of. best of luck!
fasterthanyou
Post by fasterthanyou »
if your BOV blows off to atmosphere this could be the problem. mine runs rich after blow off. i tightened the spring so it is not as bad but still runs a little rich after pushing her. normal driving it is fine
EDIt: the MAF measures all the air going in, and if your BOV is not recirculating, the computer gives fuel for all the air going in, including that which was blown off. causing it to run rich
darkcrave
Post by darkcrave »
I have a aftermarket BPV, going back into the intake. I cant figure it out.
The car becomes so rich under WOT the car bogs
Tune
TMIC
Fuel
Taillight
Has it always been running this way, or did it just happen? If it's been running like this since installing the Robtune, I'd suggest contacting him to see if he has any suggestions.
darkcrave
Post by darkcrave »
No, I took it to the track after the robtune. It ran much better at the track then it does now.
its progressively getting worse. again... only in WOT
Tune
TMIC
Fuel
Taillight
BoostedSubie
Post by BoostedSubie »
Is that an ebay bpv? I'd check to make sure its not floating open under load. I had a cheapo ebay bov at one point that would float open and do something similar. Swap in the factory one or a get a cheap Volvo/Saab one from a wrecking yard and see if it runs any better.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
99 Black Legacy GT wagon
darkcrave
Post by darkcrave »
Good idea, let me swap another one and test it out!
Thanks!
Tune
TMIC
Fuel
Taillight
darkcrave
Post by darkcrave »
After poking and poking and poking.... Its was my spark plug gaping. Spark was blowing out during WOT :cry:
Tune
TMIC
Fuel
Taillight
What gap were you running?
darkcrave
Post by darkcrave »
The gap was the stock NGK Gap, which was around .45
Tune
TMIC
Fuel
Taillight
Stock gap really shouldn't be more than .043".
The stock gap range is 1mm - 1.1mm, which is .039" - .043"
I'll go to .044" sometimes, but I wouldn't go too much further, especially on a turbo car. If your ignition system is weaker, then a smaller gap would be better.
darkcrave
Post by darkcrave »
I droped it to .028, Im not sure if thats too small now. I just added the MSD + 8mm wires.
Tune
TMIC
Fuel
Taillight
Yeah that's probably a little too small, but you can see if it makes any difference.
