Danny-G
Post by Danny-G »
Gonna wash the wagon, put the stero and digi compass from the sedan in the wagon, and try to set up some sort of long distance light kit for the wagon as well. I might need something like that for I-90.
Danny
Thesubielover
Post by Thesubielover »
Just swapped in the silicone 90 for the POS hot water rubber 90 I was using. Do me a favor, and never buy a hot water heater 90 or the turbo inlet. You'll do like I do an choke more then half of the power band and then realize "oh, i should just have ordered a silicone 90" lol.
No bueno
Danny-G
Post by Danny-G »
Didn't wash the wagon but I did get the stero and digi compass installed in it along with the amp and two subs I have and I got rid of the wind noise by simply clamping the mirror mounts together for a few seconds. So much quieter in the car now, only need the stero at ten instead on fifteen. I don't think I'm gonna make a light kit for the wagon, the headlights are actually pretty decent with 100/55w headlight bulbs.
Danny
SWRT
Post by SWRT »
What color will it be?
Mine's that same green color. I'm not a huge
fan of it.
Danny-G
Post by Danny-G »
Paint the door handles at the same time!
Danny
silver03
Post by silver03 »
The paint will be the same color. I dont want to have the jams and engine bay resprayed.
Dominator
Post by Dominator »
Here's my time slip from last weekend.
Thesubielover
What r u running turbo/engine wise for you 1/4 mile time?
Dominator
Post by Dominator »
Just stock configuration.
Stock block and heads, VF-11, non-intercooled, 4EAT, full leather interior, 90 octane...
I wanted a baseline to compare to when I switch everything over.
Soon: TD05, STI yellows, 07 Intercooler, Rob tune ECU, and other supporting mods.
Just washed the outside of my windows, gotta make sure i can see good on my way to wcss
Did an oilchange (Rotella 10w30 - only comes in gallon bottles, so I have to buy 2 gallons every couple changes).
Put in some Subaru Extra-S in my tranny. Thanks Steven! Feels great, much better than the Walmart "Supertech" that I was using to clean all the rust and grime out (tranny was sitting for years with the drain plug open :(). I've also put the AndrewTech formula (3qt Redline lightweight shockproof, .7qt Motul) in another Subaru, and ran Redline in a high mileage toyota truck for years - and the extra-s feels as good as those. Guess I'll find out during the winter if there's any noticeable difference in gear changes or etc. Overall I'm happy, and it's as good so far as the Andrewtech/Redline while costing slightly less (if you have a hookup).
Put a 1st gen Power Steering Reservoir on my DOHC power steering pump. Thanks for the idea, Kimo. Now my hood closes all the way. :) I was reading that Josh put a spring from a turbo power steering pump, and that reduced power steering assist. How would I swap it/where is it/will it fit? I recently changed from the stock SS pump to this mid 90s DOHC Legacy pump, and the steering wheel feels ridiculously light now. Can't reuse the SS pump as the DOHC lines doesn't thread in.
Danny-G
Post by Danny-G »
Drove 8.5 hours to Coeud d'Alene yesterday. Wagon made it just fine, got 22.25 mpg with going over the pass. There are some fun looking roads over here, I really want to drive those roads and have some fun but I can't really leave on my own over here. I would probably get lost lol
Danny
mike-tracy wrote:I was reading that Josh put a spring from a turbo power steering pump, and that reduced power steering assist. How would I swap it/where is it/will it fit?
I think I was going to do that, but did some research and there wasn't any difference. I still may tweak the existing spring by cutting one of the end coils off to reduce the overall force it exerts, but haven't really gotten that deep into things yet.
The spring is behind the little valve body on the discharge side of the pump. If you remove that big hex nut thing on the discharge side and pull the little valving out, the spring will be behind there.
randomiam
Post by randomiam »
Well. Installed the replacement passenger fender.. Its a slight upgrade over the previous one as the frontend looks a little bit better.
Driver side CV axle was replaced.. Never realized how easy it was on these cars. Click click click, goodbye.
Subaru-less
Thanks Josh, I'll play around with my spares. If not the spring, what would make the SS pump provide less power assist, and how do I make my DOHC pump do the same?
I think the spring should do it. I'd like to take apart one of the newer pumps with the electrical connection. I think it does something in there to reduce assist at speed, but increases assist at parking speeds.
Do you have any spare springs you'd be willing to part with?
Legacy777 wrote:I think the spring should do it. I'd like to take apart one of the newer pumps with the electrical connection. I think it does something in there to reduce assist at speed, but increases assist at parking speeds.
Sorry Josh, by spares, I mean my car's original 91 SS PS pump, and a 2nd gen legacy SOHC pump. Blackbart'd be the man to ask - saw he was on recently. :)
oldscoobyturbo
Post by oldscoobyturbo »
did a front end swap to a prefacelift style on my turbo wagon. turned out really good and I customized the rad support and rebar to save time (not that it did).
adding pics
Last edited by oldscoobyturbo on Tue Aug 21, 2012 2:22 pm, edited 3 times in total.
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
diesel devil wrote:did a front end swap to a prefacelift style on my turbo wagon. turned out really good and I customized the rad support and rebar to save time (not that it did).
OK.... you can't just post that without pictures, lol
+1
Danny-G
Post by Danny-G »
+3
I replaced a fog light bulb today on my wagon. Thats all.
Danny
SWRT
Post by SWRT »
Crap that turned out good :D
Nice, smooth lines. Nothing out of place.
Good job!
I prefer the 90-91 over 92-94 any day.
Been thinking of getting that front end
for my green one.
oldscoobyturbo
if I ever do that again I'll get the rebar and the rad support had to spend 2 hours cutting it to fit
the lights and grill are not perfectly even but very close
