And im going to look in chapter 6 after work like it says and ill have more info
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
I also found this..the order of operation for testing code 41 is some were towrds the middle of thos thread.... http://bbs.legacycentral.org/viewtopic.php?f=2&t=47744
Look in there might give some insight for other problems as well.
-Thanks for all your help dillonr92. This is really helping me. If you have anymore info on this, PM me or I'll PM you. We should get this thread back on topic.
-Joe
-Joe
No problem. I stand at a cnc machine all day with nothing todo but load and unload parts. So i spend a lot of time on the bbs..... And yes we should.. i am hopfully getting some new 17s tonight to throw on my subie. Also got a diamomd coil pack and a jecs MAF....
I cursed at mine because I can't seem to keep my greytop injectors from sticking.
1989 Cherokee-lifted, locked and beat up
1991 Legacy L 5MT AWD with EJ20G swap SOLD... and rolled :(
1993 Turbo Wagon resurrected with '95 WRX guts
Got some 17s lastnight. Spun my springs back.. Some one had my front end apart and had the springs spun so the bottom end of the spring didnt set in the bottom hats notch for the spring.... Confusing unless you seen it.... But fixed hopfully.. .... I cleaned more shit under the hood. Srill tryin to figure out y my BCS area is clicking.rapidly also my accel prob. .... Also ran into this........after i got my rims last night the kid text me saying he wamted my turbo rims.......read the rest i copied and pasted my post in wheels and tires section...... Turbo rims in good condition..... Im tryin to decide if i want to keep my stock rims as they are not in abundance and mine are Fuxkn clean..i have17s on. So these are extra.. This kid wants to trade me 3" wrx exhaust For them but he also wants my brand new 2.5" strait piped magnaflow to go back on his car ... I dont feel its worth it maybe if he had his own exhaust to go back on his car.. ... Also another thing is hes got some 18" 5zigs... Why dose he want my stock rims so bad? Should i hold on to them? I feel the rims are almost more rare than the car?? Help?
I finally finished my hybrid UK gauge cluster today. I got the odometer adjusted and everything's ready to go with it. I need to redo some of the wiring in the dash, and then it'll be ready to go back in the car.
More info, pics, & video can be found here:
http://bbs.legacycentral.org/viewtopic. ... 50#p405150
took my Ver8 equal length twin scroll header from this
to this...
and finally to this
still unsure if i should delete that cat though....
to this...
and finally to this
I think you should... That way it doesnt break down and go in your turbo..
Now that i took a closer look, i dont see a cat in there... What spot are you referring to?
was making a joke about the kitty cat in the photo...
The one with the tail and fur.
Charles
Hah, What i looked at that last pic on tapatalk last night I couldn't even tell that was a cat... I actually thought it was old exhaust shields. Small picture got the best of me...
Good joke about the cat
Indeed, put me on the Blonde side for sure.
Got the beast started yesterday and the HGs blew out within 2 mins of me getting it running... FML! Any suggestions on brand/ mat'l for hg? Oem p#/ price?
93 Winestone TW project
Well i was considering doing a metal hg
If you do a metal head gasket, you should have your head and block surfaces machined, as the metal HG's aren't too tolerant in surface imperfections.
Agreed...as a machinist the surface finiish on the matal HGs will not be to a specific tolerance one side may be a thousandth diffetence then you have a leak because you got you heads machined and there granet top flat. The best bet is subaru ordered oem HGs.
I am a machinist myself, i would be surface grinding them myself after i received them because i do not trust their QC departments lol
And i would run a nice big oil stone over the head and block surfaces
Deffinatly camt go wrong with doing your own finish ive been working on a cnc latly and not to impressed with how much sanding and deburring i have to do. I make fly reels so they need to be diamonds. As they are $1100+ (saracione fly reels).
current job (and past jobs) is Proto-trak work was doing stuff on mazaks a bit before but i'm making stuff for milk testing and production machines. was making hull penetrators for the virginia class subs at one point... sonar arrays and bose speaker parts. unimpressed with the quality of parts i'm getting lately...
OEM gascap installed, went through and checked fuel lines.. engine bay to fuel pump access cover; We found a wet spot near my tank
Its at its worst when its a full tank of gas.. Draining tank, really hope I don't have to drop the gas tank.
New wipers
New wipers
Subaru-less
