started off by pulling the engine.
swapping intake manifolds and turbos.
few beers later.
engine in the 91ss and started putting the acc. back on.
everything installed and started right up.
Im definitely keeping the 93ss.Someperson wrote:Thought u were gonna keep her?
Wait, squeaking when it was closed? What causes that?!cj91legss wrote:No more squeaking too.
With great help from Alphius, we tested the forester engine (bent intake valves on cyl 3 causing 70% leakdown), and swapped in my good engine from the SUS. Car runs awesome.mike-tracy wrote:Bought a Forester. My 3rd 98 lol.
With all the stuff that you've undertaken I find it odd you'd complain about the AWIC. While I'm not ecstatic about having to take it off again, I wouldn't say it was a difficult job by any means. Just required a lot of patience and very flexible hands to work the hose on the bottomLegacy777 wrote:I finished up my trans wiring and got the engine bay put back together (minus the battery). I HATE putting that damn AWIC back in!! In the past I had to put the AWIC and the TB on together and then try and fight to put the bolts on for the TB. I ended up getting the AWIC back in without taking off the TB....that saved a lot of swearing....there was still some though.
Now I just need to put the dash back in and finish up some miscellaneous wiring. It's getting close!
When I do my upgrades I try and keep future maintenance in mind with how I route things. The issue with the AWIC is that I'm using an aftermarket Samco hose that was trimmed just a little bit too short (my fault). So getting everything to fit together is just a huge pain in the ass.James614 wrote:With all the stuff that you've undertaken I find it odd you'd complain about the AWIC. While I'm not ecstatic about having to take it off again, I wouldn't say it was a difficult job by any means. Just required a lot of patience and very flexible hands to work the hose on the bottom
