Had to have the Impreza towed home for the 3rd time in two months. Only one more tow on my AAA until next April. Bought some new rims and wheel adapters. Getting ready to remove the 6" lift from the legacy and sell it.
Oh yeah... I moved to Puyallup last weekend so now I'll have to meet up with all you Pierce County kids.
Lifted 91 LS Wagon : SOLD
87 GL-10 Turbo : SOLD
Lifted 97 Impreza OBS
98 Impreza OBS RallyX / DD
Thanks to a dremel tool, I got my hub slotted to fit the kartboy 2-pot adaptors. Oh, and I got the internet at my new place, finally!
So are the Kartboy adapters not machined properly for our hubs?
-Cleaned and lubed my hks bov.
-Joe
-Joe
On the 1st and 2nd gen hubs I've used them with, I've had to slot one hole each time. I talked to Kartboy and they said something along the lines of the older hubs not having a consistent shape to them.Legacy777 wrote:So are the Kartboy adapters not machined properly for our hubs?
Kind of sounds like an excuse...
Replaced rear hub and threw in "new" rear axles to match the 4.44 diff on the Impreza.
pulled the oil pump/water pump and pistons from my extra shortblock *cough* moneypit *cough* and finally getting around to really tearing it down to check things out, have someone more skilled than me go through my bottom end and check things out.
maybe look for a crankshaft and extra oil squirters in the meantime..
Subaru-less
Tried to carefully clean my engine bay out with a hose and fucked something up running like shit hopefully tomorrow it will completely dry out andrun better
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
1991 Legacy Turbo
Sold 1987 Wagon
Changed the atf today... It was horrible
Weird thing is I checked it two months ago and the dipstick DID NOT show this, good thing we got it before the tranny fudged but I believe it will only last a couple more months.
Any opinions on which auto tranny I should be looking to replace on a budget? Cant decide between the 4.11 or the 4.44 and which years/phases will bolt right up. I've heard I just need the rear matching axles?
Finally decided to cut down the clutch master cylinder resevoir to make room for my ARC slanty intercooler. Hope it's not too short!
Photo of my tools and final product minus the hack saw.
Cool thread by the way
92 Sport 5MT
Gave mine a bath and cleaned my Bugeye OBS wheels. Theyre silver again
Grabbed a cheap Ej20G short block today. Same deal as I sold you one for Kimo.
-Put t-bolt hose clamps everywhere for my front mount. Also my coolant decided to give up on me so luckily had a wrx tank for a backup so put that in, finish it up tomorrow.
-Joe
-Joe
Made and installed a mbc. It seems to work fine so far.
Danny
The Legacy turned 195,000 miles last night.
-Well finally finished my wrx coolant tank install:
-Joe
-Joe
Those things fit really nice in that location! It's too bad I MUST keep the A/C. It's just too freaking hot and humid to do away with it.
Installed the last amp positive wire. Now I just need two more amps lol.
Danny
Put the second amp in my wagon and got my friends new to him 93 l wagon to my place for some work on the auto. Everything about his wagon is great, other than the slipping auto.
Danny
Made a half assed air intake pipe that gets fed by the fog light hole on my wagon and put mud flaps on my friends wagon along with fixing all the dash lights. Tomorrow we swap transmissions.
Danny
Finally got my EJ20G and 4.11 5spd in place. Now to hook everything up, and do the rest of the 5spd swap.
Lowered the Legacy and lifted the Imp this weekend.
Still some tidying up to do on both cars to make them road worthy.
Oil Change and tires rotated.
