I stopped for awhile and then started again and its still got one thats ticking. Probably half an hour or so now... grrr
Drove the 91 yesterday after it had been sitting since august when I bought it. Drove it to try and get that lifter some oil, no go... Guess I'll buy some later.
robertpaige
Got a much needed bath. Here's some FMIC pics too
robertpaige
Fixed lifter tick. I have a daily driver now while i start on my 92 prefaced ss!!!
free5ty1e
Awesome fmic install robert! Id def subscribe to a write up on how to duplicate. ..I still have a stock SS that needs one
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
-Chris
91SS 4EAT stock, 200k mi
Waiting on Subaruparts.com to send the parts I need to get her back up and running. I just want to drive her!
subaru_styles
1994 SS "JDM-OEM"
1992 rhd BF5 gt
1992 rhd BF5 gt
Gave the 91 a bath for the first time today. It'll make its way to the car lot as soon as im comfortable that everything is in good standing.
Did my shifter bushings. Ungodly pain in the ass (I wound up dropping the trans mount while the trans was on a jack stand), but soooooooooooo worth it! Took a while to get used to having a dogleg 3rd gear movement, as oppossed to just pushing in a kinda centerish direction in a straight line.
Did an oil pressure test just because. Came up with 30-32 at idle.
Sent from my SCH-I545 using Tapatalk
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
Spent several hours spring cleaning my garage and 20 mins working on the subaru. Got it jacked up on stands and both wheels off. Removed driver's side knuckle and I'm ready to press out the bearing and replace it and then its on to the passenger side.
robertpaige
Looks like I'm doing an EJ20G swap..
Pic from today.
Pic from today.
robertpaige
Sold the old SS and picked up a new one. 550 RobTune, TD05, FMIC, BC coilovers, XXR wheels.
5 speed swap. 50% done.
getting all put back together today and tomorrow. Went way over my budget. Bank accounts empty, thanks to subaru genuine parts
I think quite a few of us can relatedillonr92 wrote:Went way over my budget. Bank accounts empty, thanks to subaru genuine parts
Oh yeah, we sure can...
originalcyn
Changed the bulbs in the high stop lamp (4th Brake light). A lot easier to get to than I was expecting, which was a nice surprise.
Also re-balanced the front passenger wheel. Apparently when she got in the wreck in February, my friend also managed to curb the wheel and knock off a balancer.
dankberries
Installed a fmic and td04 on the SS. Slightly bummed about hacking my bumper support. In the future when I have more time, I think I want to relocate the fmic where the a/c condenser would sit. I also started learning some tig welding, pretty excited to have access to a tig setup finally. Lots of good things to come from it.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
90 Nissan 240sx 2jz
Started hacking my exhaust, to make it fit better. Relocated the extension from between the midpipe and catback, to right behind the muffler, also gonna get my hangers relocated. Should result in much better fitment going under my differential.
free5ty1e
Got a Maaco paint job on my old white 94ss that used to have some rust concerns:
-Chris
How much do they charge these days?
free5ty1e
The paint job itself was about $700 but I had another $700 in prep charges (had to strip a couple pieces bare and repair some quarter panel rust).
I could have easily racked up another $1000 in bodywork tp fix all the dents and such but couldn't justify it.
I just didn't want the body to rust away to nothing around a perfectly good ej22t
-Chris
Good deal. It looks good.
I completed my five speed swap from hell last night. And for some reason only God knows I put the fuckin shift interlock back in and got my key stuck in the ignition. So i searched and searched till I found a thread about it. Only difference was he didnt put his car in park or neutral before removing it. so it shows there is a super incognito button in the steering column that releases the key. So i pushed that amd havnt had an issue.. I just need to pun the ecu and what not. I can then remove the gear selector from the engine bay and have my reverse lights. It also wants to die at idle, so I'm hoping finishing the wiring will fix all that.
Yeah, finish the wiring before you try to start/run the car. That should take care of the issues.
Don't forget the AT/MT identifier pin.
