Has anyone successfully fixed air leaks from the seals around the front doors? My drivers door seal really whistles once I am going over 40mph.
I wonder if there is any window adjustment possible
Has anyone replaced the seals? Probably too expensive.
thanks
wind noise from leaky front door seals - adjustment possible
1/4" polyethylene pneumatic tubing I stole from work between the folds of the weatherstripping works well for me. I did the leading edge from the side view to a little around the corner at the top front of the window. Has worked well for years. Watch out that it stays there, though - for some reason I've had windshield-replacement idiots remove them for me and not replace them.
boostjunkie
BAC5.2
I just used some 8 gauge ground wire behind the weather stripping to help seal.....it works for the most part.
petridish38
There is a way to adjust the "preload" on the glass so it seals better... The Haynes manual describes it, and i'm not sure if the FSM does or not......
Andrew
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
http://bbs.legacycentral.org/viewtopic.php?t=16143
Take a look there, try that and let me know if it works for you, it surely worked for me
Neo
Neo
1990 L 2wd 5spd 215K miles
