wind noise from leaky front door seals - adjustment possible
mp
Post by mp »
Has anyone successfully fixed air leaks from the seals around the front doors? My drivers door seal really whistles once I am going over 40mph.
I wonder if there is any window adjustment possible
Has anyone replaced the seals? Probably too expensive.
thanks
1/4" polyethylene pneumatic tubing I stole from work between the folds of the weatherstripping works well for me. I did the leading edge from the side view to a little around the corner at the top front of the window. Has worked well for years. Watch out that it stays there, though - for some reason I've had windshield-replacement idiots remove them for me and not replace them.
boostjunkie
Post by boostjunkie »
I think Legacy777 just said to roll out the weather stripping to make a better seal.
BAC5.2
Post by BAC5.2 »
I did what Steve did on my 95. Worked great.
I just used some 8 gauge ground wire behind the weather stripping to help seal.....it works for the most part.
petridish38
Post by petridish38 »
There is a way to adjust the "preload" on the glass so it seals better... The Haynes manual describes it, and i'm not sure if the FSM does or not......
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
nsantos23
Post by nsantos23 »
http://bbs.legacycentral.org/viewtopic.php?t=16143
Take a look there, try that and let me know if it works for you, it surely worked for me
Neo
1990 L 2wd 5spd 215K miles
