offsets
azn2nr
offsets
Post by azn2nr »
ok im confused . when the offsets get bigger in number the wheels stick out less and when the numbers are smaller they stick out more?
-jason
Yes, that's right.
azn2nr
Post by azn2nr »
i want to get rims that sit flush with the fenders not tucked inside or sticking out. would 42s work or would they stick out too far? and the same question for 48s
-jason
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
you may just want to go to a les schwab or something and see if they'll let you test fit. some places do
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
THAWA
Post by THAWA »
it depends mostly on what width the wheel is
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
THAWA wrote:it depends mostly on what width the wheel is
Werd. . . increased width will almost always mean a different offset, to keep the wheel's mass centered around the hub. :P
a larger positive offset will suck the wheel into the fender. You'll most likely rub with anything less then +45mm of offset.
AZJEFFRO
Post by AZJEFFRO »
I just put Rota's on my 90 wgn. at 48 mm they fit perfect.
