Moderators: Helpinators , Moderators
azn2nr
Posts: 2412 Joined: Sun Nov 30, 2003 8:02 am
Post
by azn2nr » Wed Apr 14, 2004 2:21 am
ok im confused . when the offsets get bigger in number the wheels stick out less and when the numbers are smaller they stick out more?
-jason
Posts: 12517 Joined: Sun Nov 03, 2002 2:13 am
Post
by vrg3 » Wed Apr 14, 2004 2:49 am
Yes, that's right.
azn2nr
Post
by azn2nr » Wed Apr 14, 2004 7:16 pm
i want to get rims that sit flush with the fenders not tucked inside or sticking out. would 42s work or would they stick out too far? and the same question for 48s
-jason
LaureltheQueen
Spelling Nazi
Posts: 4644 Joined: Fri Aug 29, 2003 7:14 am
Post
by LaureltheQueen » Wed Apr 14, 2004 7:19 pm
you may just want to go to a les schwab or something and see if they'll let you test fit. some places do
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
THAWA
Posts: 6829 Joined: Thu Aug 21, 2003 7:44 pm
Post
by THAWA » Wed Apr 14, 2004 7:26 pm
it depends mostly on what width the wheel is
Yukonart
Cradle Robber
Posts: 2655 Joined: Wed Aug 13, 2003 10:45 am
Post
by Yukonart » Wed Apr 14, 2004 7:36 pm
THAWA wrote: it depends mostly on what width the wheel is
Werd. . . increased width will almost always mean a different offset, to keep the wheel's mass centered around the hub.
Posts: 27932 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Thu Apr 15, 2004 12:17 am
a larger positive offset will suck the wheel into the fender. You'll most likely rub with anything less then +45mm of offset.
AZJEFFRO
Posts: 11 Joined: Wed Apr 28, 2004 9:53 pm
Post
by AZJEFFRO » Wed Apr 28, 2004 10:42 pm
I just put Rota's on my 90 wgn. at 48 mm they fit perfect.
