Front wheel drive fuse??
Tleg93
Post by Tleg93 »
I have a question about the FWD fuse undeneath the hood of a 91 turbo sedan 4eat. What's up with that thing. Does it have to have a fuse in it to run at FWD or is it with the out that it runs in FWD???
Oh, and can anyone tell me if in the case of AWD if the rear wheels should turn with the front wheels on the same car mentioned above (91 turbo 4eat)? The reason I ask is because a tech put my 92 NA 5mt sedan up on a lift and showed me how turning one of the wheels makes the others move in unison. Is this only on a standard or what, can anyone help?
--Scott--
1991 - Rio Red SS
91White-T
Post by 91White-T »
The FWD fuse will make the car FWD, it's for diagnostic purposes and whatnot... Youre technically not supposed to drive around with it like that, but why would you anyway? Also a "FWD" light will come on the dash when you put the fuse in. The wheels should all turn.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
Tleg93
Post by Tleg93 »
Cool, thanks man. I've never seen one of those before so I had to ask.
--Scott--
1991 - Rio Red SS
If you have an owner's manual.....it'll have all the info in there you need.....if not....i've scanned mine for your reading pleasure ;)
Tleg93
Post by Tleg93 »
Right on, I could probably utilize that scanned version as I'm not sure if the car I'm getting has a manual with it. If it does I'd still want to check it out so I have a back up copy. Is that a .pdf file per chance?
--Scott--
1991 - Rio Red SS
THAWA
Post by THAWA »
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Tleg93
Post by Tleg93 »
Thanks a bunch, man.
--Scott--
1991 - Rio Red SS
dagsy
Post by dagsy »
so for the sake of better fuel economy, would driving with this fuse in all the time be likely to do any damage to the drivetrain?
It shouldn't help fuel economy much as you're still moving all those parts.
dagsy
Post by dagsy »
what about any damage that could be done? and just for interests sake, i changed a constant 4wd to free wheel front hubs on a mitsubishi pajero(in oz) and it made quite a difference to the economy i was getting
There may be a risk of overheating the duty solenoid that regulates MPT clutch lockup.
dagsy
Post by dagsy »
what will that do? should i just give it up and take the fuse out
Overheating the solenoid? I would guess that once that happens, the valve would cease bleeding pressure off, and you'd end up with full front-rear lockup all the time, much like an off-road truck.
