Front wheel drive fuse??
I have a question about the FWD fuse undeneath the hood of a 91 turbo sedan 4eat. What's up with that thing. Does it have to have a fuse in it to run at FWD or is it with the out that it runs in FWD???
Oh, and can anyone tell me if in the case of AWD if the rear wheels should turn with the front wheels on the same car mentioned above (91 turbo 4eat)? The reason I ask is because a tech put my 92 NA 5mt sedan up on a lift and showed me how turning one of the wheels makes the others move in unison. Is this only on a standard or what, can anyone help?
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
The FWD fuse will make the car FWD, it's for diagnostic purposes and whatnot... Youre technically not supposed to drive around with it like that, but why would you anyway? Also a "FWD" light will come on the dash when you put the fuse in. The wheels should all turn.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
If you have an owner's manual.....it'll have all the info in there you need.....if not....i've scanned mine for your reading pleasure
It shouldn't help fuel economy much as you're still moving all those parts.
Overheating the solenoid? I would guess that once that happens, the valve would cease bleeding pressure off, and you'd end up with full front-rear lockup all the time, much like an off-road truck.
