sqc151
Post by sqc151 »
Thanks to frank and alex we pulled the engine from my 93ss and swapped it into my 91ss along w/ a evo3 16g turbo, swapped intake manifolds w/ 440 jdm inj, brand new radiator and more. Started right up and drove. Now just gonna clean the car up a bit and get it ready to sell.
started off by pulling the engine.
swapping intake manifolds and turbos.
few beers later.
engine in the 91ss and started putting the acc. back on.
everything installed and started right up.
Isn't it nice when things just work right?
sqc151
Post by sqc151 »
yea, ive always been lucky with that. (thankfully) you just have to take your time and make sure everything is right and tight. it took 10hrs to remove and install the engine and start it, but in the end it was worth it.
i mean... everything works, we even custom mounted the coolant tank.
installed a brand new radiator which was for my 92tw, so now i gotta get another one.
today, im gonna take it to the car wash and clean up the whole car. get er nice n shiny and vacuum the interior.
Someperson
Post by Someperson »
Thought u were gonna keep her?
93 Winestone TW project
replaced my wagon sunroof track with a sedan sunroof track and eliminated that stupid stop feature when closing the sunroof. I'm much happier with it now. No more squeaking too.
sqc151
Post by sqc151 »
Someperson wrote:Thought u were gonna keep her?
Im definitely keeping the 93ss.
the 91ss i got with a bad engine, so i swapped my 93ss in to sell it.
I wanna keep my 92tw for a daily, so i have to sell the 91ss to get the engine work done.
sqc151
Post by sqc151 »
welp. got the suspension all set, new mesh grill, all washed up and vacuumed.
tomrw, ill be installing wrx seats and new radio.
originalcyn
Post by originalcyn »
cj91legss wrote:No more squeaking too.
Wait, squeaking when it was closed? What causes that?!
Kijan
1993 Legacy LS | PBM 227
Mine was squeaking because i had a wagon sunroof assembly in my sedan. Thw back corner holes dont line up with the studs on the roof.
originalcyn
aw dang. ok, thanks CJ.
Kijan
mike-tracy wrote:Bought a Forester. My 3rd 98 lol.
With great help from Alphius, we tested the forester engine (bent intake valves on cyl 3 causing 70% leakdown), and swapped in my good engine from the SUS. Car runs awesome. :)
Dominator
Post by Dominator »
I replaced a locked up seatbelt track in my 91 SS this weekend. It decided to stop working Friday night. I'm glad I have a few parts cars to pick from. Next time, I think I'm going to convert to the manual belts like a lot of you have done.
alexandermf
Post by alexandermf »
This is more of a 2am night project for kicks and giggles after working a long double, needless to say they were caked with brake dust before and this is an hour later
Cool edit, looks like a floating rim :P
Dominator
Post by Dominator »
Those wheels are hot!
Yeah, they do look good!
alexandermf
Thanks!! They def have not been that clean since I owned the car :p ill take some pics in the sunlight today
CAV3MAN227
Post by CAV3MAN227 »
-Got the clutch replaced, w00t!
-Joe
turbo970
Post by turbo970 »
found a leaking pan gasket today on my freshly rebuilt trans. taking the car and teh pictures to the shop to have it fixed. i'm pissed
Chances are they either didn't use the right gasket, tighten the bolts properly, or didn't flatten out the pan mating surface. The bolts can sometimes deform the pan around the bolt holes and this causes the pan not to seal well.
James614
Post by James614 »
Legacy777 wrote:I finished up my trans wiring and got the engine bay put back together (minus the battery). I HATE putting that damn AWIC back in!! In the past I had to put the AWIC and the TB on together and then try and fight to put the bolts on for the TB. I ended up getting the AWIC back in without taking off the TB....that saved a lot of swearing....there was still some though.
Now I just need to put the dash back in and finish up some miscellaneous wiring. It's getting close!
With all the stuff that you've undertaken I find it odd you'd complain about the AWIC. While I'm not ecstatic about having to take it off again, I wouldn't say it was a difficult job by any means. Just required a lot of patience and very flexible hands to work the hose on the bottom :)
CAV3MAN227
-Fixed my axle.
-Joe
I finished installing my interior yesterday Need to find new back seats.
James614 wrote:With all the stuff that you've undertaken I find it odd you'd complain about the AWIC. While I'm not ecstatic about having to take it off again, I wouldn't say it was a difficult job by any means. Just required a lot of patience and very flexible hands to work the hose on the bottom :)
When I do my upgrades I try and keep future maintenance in mind with how I route things. The issue with the AWIC is that I'm using an aftermarket Samco hose that was trimmed just a little bit too short (my fault). So getting everything to fit together is just a huge pain in the ass.
James614
Post by James614 »
I've got the Samco hose too. I almost forgot about trimming it, that was a bitch to get right. Yeah if its a tad too short that would definitely make me swear a little...
Put in a new coolant tank and re routed some hoses. Ill add pics to my build later.
