mushy suspension
sktngisnotacrime
mushy suspension
Post by sktngisnotacrime »
the suspension on my car seems to be much softer than on most cars. is there ANY way to stiffen it without buying lowering springs.????
just wondering, thanks
Legacy
How old are the struts?
The first time I replaced struts on a car, the first drive afterwards was like an epiphany. I simply never realized how much the worn struts were detracting from the car's personality, because they wore out so slowly.
sktngisnotacrime
struts
i dont think they have been replaced, so they are probably 10 years old
Legacy
Then I strongly suggest getting a set of KYB GR2s. The GR2 is a very good aftermarket strut. They should cost you about $70 a corner and will dramatically change your car's feel.
Brat4by4
Stratified
Post by Brat4by4 »
Don't forget replacement springs, too. Fresh springs and shocks all the way around will make a world of difference. And I do believe your car lacks a rear sway bar... installing one will help heaps also.
You don't even need to do springs. Springs is one of those things that "technically" you don't need to replace....or shouldn't have to. Put new struts on and it will be night and day. Trust me.
Slick1100
Post by Slick1100 »
vrg3 wrote:Then I strongly suggest getting a set of KYB GR2s. The GR2 is a very good aftermarket strut. They should cost you about $70 a corner and will dramatically change your car's feel.
Ok, where can I find a GR2s for $70 a corner? I also need front strut mounts for my car, and I'd prefer not to pay an arm and a leg for them.
Rob
'98 Subaru Legacy Outback
'09 Toyota Prius
'07 Kawasaki KLR650
mTk
no title
Post by mTk »
tirerack.com has em for $58 each
MK
1992 BC672 AWD 5MT
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
I can get all 4 for $220 through sears. But that's just cuz I know people.
My bf tracked this down for me as well, it may be of some use to youhttp://www.autocarparts.com/cars/Subaru/Legacy ... nsion/ALL/
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
scottzg
Post by scottzg »
how great for you! Does that mean you're gonna hook us up?
Sears carries KYB GR2s? I've only seen Konis and Monroes there.
Jr.SubaruLvr
struts
Post by Jr.SubaruLvr »
i checked on tirerack and the struts are $108 each.Where can you find them for under $60?Thanks
mTk
no title
Post by mTk »
It's right on tirerack's site.. $58 each
try this link: HERE
MK
1992 BC672 AWD 5MT
Jr.SubaruLvr
struts
hey MK are the sedan and wagon struts the same.Thanks for the link by the way
Jr.SubaruLvr
strutts
i know why my search turned out $108. i entered my veichle as a 1990 legacy wagon and if you enter it as a 1992 it gives you $58. Now i know that this is already somewhere in the bbs, but will a 1992 fwd legacy wagon strut fit a 1990 fwd legacy wagon with tapered springs? Thanks p.s. i'm looking for rears by the way.
mTk
no title
Post by mTk »
Ah, hmm. Yeha, i'm sure it's on the board somewhere... but i believe the only difference w/ tapered springs was the top mount.
MK
1992 BC672 AWD 5MT
