HKS SSQV whistle delete :)
Front, Top, Air, Water.
free5ty1e
Post by free5ty1e »
So, I got really tired of that damned SSQV whistle, and realized that the piece that creates it is just an insert sandwiched in between a rubber seal and the outer casing.
8 allen screws (2.5 mm heads) later and it's out, putting the BOV back together reveals that only 4 of the screws hold the casing on, the other 4's heads pass through the casing and just hold the seal onto the valve itself. Pretty nifty design, even just on the outer casing.
They sell a purple insert that replaces the factory silver one, that doesn't have the turbulent parts in the airflow - so therefore no whistle. They also have a gold insert for aesthetics, with zero sound difference from the silver. But instead of dropping $25 on one of these inserts, I found that the unit goes back together quite nicely without any insert whatsoever.
I will be driving around town shortly and will see how it sounds... it's GOTTA be better than before :roll:
-Chris
91SS 4EAT stock, 200k mi
free5ty1e
Post by free5ty1e »
Update: sounds WAY better. I no longer yearn for my Type S. Now I've got all the advantages of the pull-type BOV and none of the signature SSQV whistle :)
-Chris
def09
Post by def09 »
Do you have it on a tmic or fmic? Or do you any pics of it mounted?
free5ty1e
Post by free5ty1e »
FMIC.
And um.... actually yes I do have a photo with it installed:
It's between the chimney and the plastic engine cover. Not the best shot in the world but there it is.
-Chris
Bheinen74
Post by Bheinen74 »
do you drive the car with the headligts/corner lights not fastened in, like in the picture. Don't they fall out at highway speeds :shock:
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
def09
Post by def09 »
Cool bov indeed! Hmmm, I never noticed a fmic when the stock airbox was still used. The piping looked like quite a chore to run. Is it all 3" exhaust type pipe. and did you just ditch you washer bottle?
free5ty1e
Post by free5ty1e »
What makes you think the headlights aren't attached, other than the fact that the stock mounts aren't used in the traditional sense...? :)
No really I had to space the headlights out to make room for the FMIC, and then re-secured them using a combination of straps of metal, bolts, mechanics wire, and zip ties (of course). Took a few tries to get them secured but they're not going anywhere.
Oh and the FMIC piping is 2.5" press-bent exhaust piping, the entire project used less than a single 7' $35 section (with a couple 90* bends in it). It was not easy to do but I'm very pleased with the results.
I removed the washer pump from the original bottle, purchased a $9 Ford washer bag from eBay, and hung it behind the passenger side headlight with zip ties. Mounted the pump slightly below and behind the bag and ran the tubes, and I've got windshield pissers again. Also poked a safety pin into the nozzles and now all 4 sprays operate. Woohoo!
-Chris
Post by BAC5.2 »
Chris - HKS makes a recirc kit for the SSQV. I don't remember much about it, but I believe it's a whole replacement outer cover. You can keep the whistle, AND recirc the BOV, or you can use the purple silencer kit.
I THINK their "racing" version (that's rated to 49psi) comes standard with this recirc. adapter.
Here's a pic:
http://images.snapfish.com/3465646%3B%3 ... 6742ot1lsi
free5ty1e
Post by free5ty1e »
Yeah, I was looking at the recirc adapter, and am planning on at some point getting one on general principle. Either way though the stock whistle was just too much for normal driving, I'd imagine even with a recirc kit on there the whistle would still drown out the engine on light shifts :roll:
And just for the record, all the purple silencer kit does is remove the element directly in the path of the escaping air that causes the whistle, and you can just remove it yourself without putting the useless purple insert in afterwards for the same results. Thereby saving $20 or so. :)
But yeah gotta love the quality of this valve... that was the feature that initially caught my interest, that was rated to hold like 50 psi of pressure with no leaks. Pull-type BOVs rule!
Edit: that photo link you posted must be of an older SSQV - it's got an adjustment bolt on the left side!
-Chris
High PSI
Post by High PSI »
I have this BOV on my GSX. The whistle is completely eliminated when the recirc kit is installed. The recirc kit is pretty much a hose and a sleeve that slides into the BOV in place of the purple or gold fitting.
How does the car run with the BOV vented?
free5ty1e
Post by free5ty1e »
Seems to run fine vented -- I had trouble with my Type S leaking after a blowoff at idle, not closing properly... but the SSQV has given me no issues. Just works.
-Chris
Post by BAC5.2 »
I actually had better luck with the TypeS than with the SSQV. That is, after Vikash and I reverse engineered it and figured out how you are SUPPOSED to set it up! What a pain in the ass!
My SSQV had the adjustment bolt, yours doesn't?
free5ty1e
Post by free5ty1e »
Nope, no adjustment whatsoever on my SSQV.
-Chris
High PSI
Post by High PSI »
Older ones, and the fake ones, do.
The latest authentic ones don't.
dzx
Post by dzx »
I've never had a problem with my type S
///M
'93 Legacy SS - part out
Post by BAC5.2 »
I guess mine was an older one then. Doesn't really bother me though. I hated the noise and it caused more problems than my TypeS.
I'd almost go on the limb to say the Type S and the SSQV are two of the better BOV's available.
