Intake hose.....
wallgood358
Intake hose.....
Post by wallgood358 »
I am attempting to find a part of my intake that i cannot seem to locate in any oem places.I noticed that one of the rubber intake snorkels was torn when i was changing my air filter today, which i think might explain a sudden loss in power thru vaccum leak. It is the last one in from the air box that goes into the manifold. There is the elbow that goes from the MAF to the big plastic vaccum box, then from there to the manifold. I need the vaccum box to manifold snorkel. Can anyone help me out?
wallgood358
I have looked at about a half dozen oem parts sites and cannot find a lsiting for any of the intake boots for this car. Can anyone help?
skid542
Post by skid542 »
I pressume you're NA and not turbo?
I don't know the part number but I have a spare NA intake tract that I'd be willing to let go for cheap + shipping. If the piece in question is the green 'highlighted' piece - http://filebox.vt.edu/users/lskidmor/pe ... intake.JPG and you're interested let me know. Otherwise I'm not quite sure which piece you need.
Lee
wallgood358
It is a turbo car. Here are a couple of pics of what i am in need of
There is a tear in the bottom part of the ribs and i think that may be part of why my performance has taken a drastic drop.
Imprezive
Post by Imprezive »
Those things are expsensive, good luck finding one.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
The Scooby
Post by The Scooby »
i have a spare in my garage. ill check tonight if i can find it (just finished moving again) and if its in good shape ill let ya know.
1986 GL wagon
EJ'ed and Lifted
wallgood358
I appreciate it. I cannot find it in any online stores or on ebay even
GotSubie
Post by GotSubie »
if the scooby dosent come through go to your local subaru parts place and they will have it. it will cost a lil more then getting it used but you cant beat quality oem parts
wallgood358
Do you know what the exact part name is for that or possibly part number?
wallgood358
bump
93Leg-c
Post by 93Leg-c »
I believe Subaru calls it an Air Inlet Duct. I don't have a part number for it, though.
'94 TW
wallgood358
I'm gonna try the duct tape solution for now and search local junkyards
Splinter
Post by Splinter »
Just remember: You're about to replace a used part with a used part.
Those elbows crack because they're made of plastic and next to a stupidly hot piece of metal. A used one will have been used under the same circumstances.
Its worth it to go to a new piece, or an aftermarket alternative (silicon hose elbow)
mr soul
Post by mr soul »
They are rubber and after heat exposure and years of driving they turn into what seems like plastic.
Search in the parts shed for "turbo inlet", more than one of us has them in good condition for less than new at the dealership but you are correct in that their are no aftermarket sources for this.
Also to anyone messing with this on your car: The heat gun is your friend, heat this all up before you yank on anything to help prevent cracking a marginal piece.
http://bbs.legacycentral.org/viewtopic.php?t=28271
Retired but still rocking a 98 Coupe with the heart of a turbo legacy :)
93Leg-c
Post by 93Leg-c »
Good tip, mr soul! Thanks!
'94 TW
Imprezive
Post by Imprezive »
I cracked mine right under where the clamp covers. I just cleaned it all up and covered it with some high temp gastket silicone. works fine!
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
wallgood358
its cracked in the middle of the ribs right before the downward curve
wallgood358
Ok new question to this old post. Since it seems to be very difficut to find a good turbo inlet, can i use this pipe i found on ebay with some vaccum hose modification and the removal of that big black oval piece that the inlet attaches to. Here is the link: http://cgi.ebay.com/ebaymotors/OBX-Turb ... dZViewItem
that's probably not going to work.
subytech
Post by subytech »
yea i think the diameters of the openings for the turbo are different. I would think the easiest thing to do would be to get a reducing 90 degree sylicon elbow from like samco and move the vacuum lines upstream if you cant find a new one. Still quite a bit of work though.
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
